查看: 17011|回复: 1
Hyperworks7.0的安装说明
发表于 2005-5-5 19:05:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Altair HyperWorks 7.0
1. Install HyperWorks, copy all files to your x:\Altair\hw7.0\security.
2. Edit lnd.dat and replace <host> in first line with your hostname.
   Replace 000000000000 with your Ethernet Address and then save it.
   DO NOT modify anything else in this file.
3. Run keygen.bat to make your ALTAIR_LIC.DAT file.
4. Set the License environment:  LM_LICENSE_FILE = 2181@hostname.
5. Run lmtools.exe and manually setup Flexlm Services. Click on the configuration
   service tab and set 'path to lmgrd.exe' with LMGRD.EXE and then set 'path
   to the license file' with x:\Altair\hw7.0\security\altair_lic.dat. Now,
   select 'use services', then click  'save service' button. Click on the
   start/stop/reread tab, and then the start server button.
   Enjoy this fine release from TEAM LND ;)
以上是Hyperworks7.0的安装说明,小弟有点不明白第4和第5两点的意思,请教哪位高手帮忙指点一下,谢.CADdrawer@163.com
发表于 2005-5-11 11:10:01 | 只看该作者
把你的软件传给我一份,我教你怎么安装
GMT+8, 2025-2-28 15:36 , Processed in 0.023035 second(s), 10 queries , Gzip On, Redis On.
