成君工作室FLOW3D培训资料
发表于 2005-11-12 14:32:45 | 只看该作者
qqqqq
qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
122
发表于 2005-11-14 15:13:27 | 只看该作者
FLOW3D压铸模流分析与田口品质工程系统结合研究
(推荐田口方法与软件)
中文摘要
壓鑄產品經常容易發生充填不足、熱裂、表面流紋與變形等缺陷,這些缺陷和射出壓力、射出速度、射出溫度與模具溫度等製程條件有密切關係。製品之開發試作一般係利用試誤法來求得較適當的製程條件之組合,但是,試誤過程既費時又無法保證穫得最佳的製程條件。近幾年,田口實驗設計法成了改善品質的有利工具,本研究結合 Flow-3D 模流分析軟體與田口實驗設計法規劃實驗分析條件,進行模流分析,應用直交表和信號雜訊比來求出最佳的製程條件。模流分析之條件組合是以 L9 直交表進行規劃設計,選擇射出壓力、射出速度、射出溫度、模具溫度控制因子,每一因子皆選擇三個實驗水準,品質目標設定為在模穴內必須具有最少固溶率、最小壓力差與最小溫度差。
由變異數分析求得最佳製程條件組合為射出壓力 、射出速度 、射出溫度 、模具溫度 ,再經由 Flow-3D 模擬結果,三目標值均有明顯改進,可有效改善壓鑄件缺陷,提昇產品的穩健性。
Die casting products very often show non-filling, hot cracking, apparent flow mark and deformation etc. These defects are closely related with process conditions of filling time, fusion temperature, cooling temperature of die and maintaining pressure etc. Generally, in the development of  die casting products, trial and error method was used to find the suitable combination of process conditions. It is time consuming and not necessarily assure the best results. Recently TAGUCHI experiment design methods are adopted for improving product quality. In this study, we combine TAGUCHI experiment design method with Flow-3D flow analysis package for simulation . L9 orthogonal table was used, and filling time, fusion temperature, cooling temperature of die, maintaining pressure, viscosity was chose as control parameters. Three levels of each parameter were selected for the experiment. Minimum solid fraction and most homogeneous temperature and pressure distribution in the die cavity, were set as the best casting conditions.
From variance analysis, we found out the combination of optimum process condition are, fusion pressure, fusion speed, fusion temperature, cooling temperature of die . An independent analytical process parameters combination was selected based on the result found for die-casting simulation, and the result shows the improvement of the product.
[ 本帖最后由 markchan 于 2005-11-16 09:15 编辑 ]
发表于 2005-11-15 15:11:04 | 只看该作者
什么东西?
124
发表于 2005-11-16 09:17:47 | 只看该作者
模流分析
田口法應用直交表和信號雜訊比求出最佳的製程條件
[ 本帖最后由 markchan 于 2005-11-16 09:18 编辑 ]
125
发表于 2005-11-19 12:43:53 | 只看该作者
为什么后面的都不能下载叱》
楼主辛苦了
不知从那里还可以下载。
126
发表于 2005-11-19 14:11:17 | 只看该作者
田口软件---很有用的制程改善和产品开发工具
工作室首页 敬请点击 https://co.icax.org/view_corp.php?corpid=114
[ 本帖最后由 markchan 于 2005-11-20 19:23 编辑 ]
发表于 2005-11-20 20:23:40 | 只看该作者
爲什麽要電腦類比
電腦速度越來越快,價格更趨便宜
可利用三維設計檔案直接進行分析
可類比肉眼看不見模腔內液態流動及凝固
預見缺陷及早修改設計
幫助提升模具設計水平
縮短模具設計生産周期
減少實際模具修改次數
可預先評估不同設計方案
可刺激設計人員提出更多新設計
FLOW-3D特點
軟體已開發二十年,成熟穩定
首創VOF流體體積法,類比自由表面的流動
使用FAVOR改良型有限差分方法簡單、穩定、準確
可用於不同平臺,如NT微機及各UNIX工作站
提供程式庫,方便二次開發
軟體功能不斷更新
GUI用戶介面輸入,簡化輸入物理邊界情況/材料特性等
可讀入STL\IDEAS\ANSYS等格式
在線求助手冊
自動選擇計算條件,無需用戶設定
提供多種計算結果總結,方便診斷錯誤。
正版熱線:成君工作室 flow_3d@126.com  13606906674
请点击https://co.icax.org/view_corp.php?corpid=114
[ 本帖最后由 markchan 于 2005-12-7 16:25 编辑 ]
128
发表于 2005-11-21 10:09:04 | 只看该作者
FLOW3D热应力研究
(不适合初学)
待续
[ 本帖最后由 markchan 于 2005-11-23 16:06 编辑 ]
发表于 2005-11-21 23:30:03 | 只看该作者
支持老大
130
发表于 2005-11-24 17:02:11 | 只看该作者
成君工作室(厦门)已正式成为FLOW3D正版软件商唯一指定技术服务机构。
       我们将协助正版用户快速提升!    -------MARKCHAN 13606906674
敬请点击https://co.icax.org/view_corp.php?corpid=114
GMT+8, 2025-4-19 01:43 , Processed in 0.023738 second(s), 12 queries , Gzip On, Redis On.
