查看: 15567|回复: 0
这个警告是什么意思?
发表于 2005-5-10 15:32:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Extrapolation is required for the SPLINE shiyan.SPLINE_2.
The X value ( 4.0750 ) should be between 0.0 and 4.0.
WARNING:    ADAMS will no longer warn for any out-of-range violations for SPLINE shiyan.SPLINE_2. Out-of-range X and Z values of spline have been used more  than 5 times.
这个警告是什么意思?
GMT+8, 2025-4-9 02:35 , Processed in 0.021660 second(s), 12 queries , Gzip On, Redis On.
