查看: 14591|回复: 0
[广告] High precision parts and tools machining
发表于 2005-5-18 16:12:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
We can provide the high-quality products and services as follows:
Manufacture capability of ultra-fine and ultra-deep for small bores: can machine holes with dia over 0.1mm, depth 8mm.
Ultra thin slow wire-cutting: Switzerland Agie Charmilles wire-cut, withthe thinnest 0.03mm, also capable of machining ultra-fine finish (0.1miu) and ultra-sharp angle (smallest 0.025mm).
Tungsten steel (hard alloy) forming machining: tungsten forming grinding,cylindrical grinding.
Ultra-long hole machining: smallest hole 0.3mmX50mm(super long), tolerance 0.002mm.
Precision cylindrical grinding: ultra-long and ultra-thin axis grinding, with precision to 2miu,coaxial jumping within 2miu.
Precision inner and outer thread grinding machining.
Precision mirror polishing. Ultra-flat surface polishing.
Any questions pls do not hesitate to contact me. Hope we can set up long term business relationship with you.
Kind Regards
Cissy Huang
TaiCang DELTA Precision Tools Co.,Ltd.
Tel:+86-512-53509141   55772599
Fax:+86-512-53560880
E-mail:1) cissy@deltatools.cn
2) cissy1981cn@126.com (for big file)
GMT+8, 2025-4-27 15:02 , Processed in 0.021139 second(s), 14 queries , Gzip On, Redis On.
