查看: 16980|回复: 3
【求助】cimt模拟加工时咋调节模拟速度?
发表于 2002-12-12 10:26:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发表于 2003-1-1 22:03:19 | 只看该作者
晕~~~怎么!!都没人知道吗???
发表于 2003-1-5 17:28:17 | 只看该作者
把加工区域放大
发表于 2003-1-7 12:40:49 | 只看该作者
There are three main things that you can do to slow down a simulation.
1. Zoom In - zooming in closer to the simulation part will do a lot to slow down the speed of the simulation.
2. Change the Tool Mode - The icons for this can be found on the top row - far right.
  - Wireframe Tool Mode. This is the fastest tool display mode. The tool is shown as a wireframe outline, and the display is updated at each new block of code.
  - Solid Tool Mode. This is the medium speed tool display mode. The tool is shown as a solid tool, and the display is updated at each new block of code.
  - Continuous Tool Mode. This is the slowest tool display mode. The tool is shown as a solid tool, and the display is updated continuously, showing the tool in motion from one block to the next.
3. Edit the tool - Before you start the simulation, go to Tool -> EditTool List, and change the Num Sides value to something greater than the default value of 16. I like to use 50.The higher the number, the slower the simulation.
GMT+8, 2025-4-23 07:25 , Processed in 0.020346 second(s), 13 queries , Gzip On, Redis On.
