查看: 16902|回复: 2
CAA: 怎么在CAA中使用ActiveX控件啊?
发表于 2005-5-25 15:59:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
还是不能用?
发表于 2005-5-25 17:41:15 | 只看该作者
On windows you can use the CreateObject and GetObject functions to access to ActiveX objects. This is not possible on Unix.
If a CAA V5 alternative exists, use it. A good example of this is filesystem acess:
  VBScript provides access to the filesystem through a set of ActiveX objects bundled with the Windows Scripting Host (CreateObject("Scripting.FileSystemObject").
This is not portable and can be replaced by the portable V5 FileSystem, File, Folder interface family, accessible from the Application object (CATIA.FileSystem).
发表于 2005-5-27 14:57:04 | 只看该作者
谢谢acoka兄
我去找找看
GMT+8, 2025-4-6 12:34 , Processed in 0.021609 second(s), 11 queries , Gzip On, Redis On.
