查看: 15646|回复: 4
仿真问题
发表于 2005-6-8 19:13:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教各位高手:我在adams/view中建立的汽车悬架模型,出现以下警告,不知什么原因。望帮帮小弟。谢谢!
WARNING:    An anomalous situation has been detected for TIRE b_jeep.TIRE_1.
   The moment arm for normal force (Fz) that causes the
   rolling resistance moment (Ty) is greater than the allowable
   maximum of 1/2 the length of the contact patch.
   CRR = 5.6250
   CRR_max = 2.36568E-02
WARNING:    For TIRE b_jeep.TIRE_3 the absolute value of the longitudinal slip ratio
   has gone beyond its maximum allowable limit of 1.0.
   Longitudinal slip ratio = 4.97331E+06.
   If the longitudinal slip ratio is positive, it will be set
   to 1.0 (braking).  If the longitudinal slip ratio is
   negative, it will be set to -1.0 (traction).
发表于 2005-6-8 20:38:42 | 只看该作者
很清楚是你的 Longitudinal slip ratio = 4.97331E+06取值太大了, Longitudinal slip ratio 得范围在+1~-1,不填为-1
发表于 2005-6-9 16:28:50 | 只看该作者
感谢你的解答。想问一下,在哪里修改 Longitudinal slip ratio
tire文件中吗还是………………
再次感谢!
发表于 2005-6-10 08:31:29 | 只看该作者
查看李军出的书中的有关整车模型的例子,里面有关于轮胎文件参数的解释,或者察看帮助文档,个人认为应该在轮胎文件里修改。
发表于 2005-6-11 10:03:57 | 只看该作者
感谢hero75816的热切解答,在下不胜感激!不过 Longitudinal slip ratio 的设置好象只有一个固定值,如何设置 Longitudinal slip ratio 啊?我试着改了几个值,问题还在。还望高手帮小弟看看!
GMT+8, 2025-4-17 11:11 , Processed in 0.024536 second(s), 11 queries , Gzip On, Redis On.
