查看: 15387|回复: 1
各位大哥 ,帮帮忙
发表于 2005-6-16 19:41:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
** WARNING ** Strain model data build ID does not match with the current
              MPI version (default model for this material is CRIMS).
** ERROR 104007 ** Shrinkage model coefficients were generated with
                   build # 2435  of solver, the latest solver update
                   was in build # 3104 .
                  &nbsplease re-select the material to update the study file
                   with the latest shrinkage model coefficients.
发表于 2005-6-16 23:01:12 | 只看该作者
重新选择材料,你用的估计是以前的模型,MPI新版本对该材料更新了,所以需要重新选择该材料以更新材料参数。
GMT+8, 2025-4-26 15:21 , Processed in 0.026440 second(s), 12 queries , Gzip On, Redis On.
