查看: 16022|回复: 0
拜求指点迷津
发表于 2005-6-25 11:05:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我要使一物体沿着轨迹曲线运动,这个轨迹曲线怎么去创建?有几种方法?用construction Geometry:spline可以么?怎么老有这样的提示:
WARNING: The resulting body is not a valid manifold solid, it does not have any mass.
ERROR: The system matrix has a zero pivot for column 7, which is associated
   with PART/3 Xdot. Consequently, the matrix is numerically singular.
ERROR: Abnormal termination encountered in Solver.
并且我在物体上和曲线上加了point-curve约束后,不能运动阿。
大家看看我做的对不对?曲线和加约束对不对?大家有没有别的好办法?
GMT+8, 2025-4-20 14:52 , Processed in 0.019935 second(s), 12 queries , Gzip On, Redis On.
