查看: 16433|回复: 4
高手们。此后处理什么改???
发表于 2005-6-25 23:46:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  本人用的是OKUMA系统.用MasterCAM9.01编程.系统后处理的那个老要改挺多地方的.怎样去掉程式里G53 Z0, 还有旋转轴A.请问一下各位大师什么改后处理,才能让上面的问题解决?
  比如:
(PROGRAM NAME - T )
(DATE=DD-MM-YY - 25-06-05 TIME=HH:MM - 23:22 )
N100 G21
N102 G90 G80 G40 G0
N104 T1 M6
G15 H00
( TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA. - 10. )
N106 G0 G90 X-30. Y-12.5 A0.
N108 S3819 M3 T2
N110 G56 H1 Z50.
N112 Z10.
N114 G1 Z-1. F763.8
N116 Y12.5 F1527.6
N294 G0 Z50.
N296 M5
N298 G53 Z0.
N300 T2 M6
N302 M1
N304 G15 H00
( TOOL - 2 DIA. OFF. - 2 LEN. - 2 DIA. - 12. )
N306 G0 G90 X-19. Y-6.5 A0.
N308 S3183 M3 T1
N310 G56 H2 Z50.
N312 Z10.
N370 Y-.5
N372 G0 Z50.
N374 M5
N376 G53 Z0.
N378 G53 X0. Y0. A0.
N380 M30
没有改时是这样子的.
    我想去掉最上面的%和最下面的%还有上面的A0.还有中间的G53 Z0。中间的A0。还有最后面的G53 Z0、G53 X0 Y0 Z0.什么改后处理????????在下面那几个地方改呢?
[post menu]
menu 1 {
"ost Processor:",
"&Change",
"&Run",
"Run &old",
"&Update PST"}
[canned text]
1. "Stop"
2. "OStop"
3. "Bld on"
4. "bLd off"
5. "M5"
6. "M6"
7. "M7"
8. "M8"
9. "M9"
10. "M10"
11. "M11"
[misc reals]
1. "Misc. real [1]"
2. "Misc. real [2]"
3. "Misc. real [3]"
4. "Misc. real [4]"
5. "Misc. real [5]"
6. "Misc. real [6]"
7. "Misc. real [7]"
8. "Misc. real [8]"
9. "Misc. real [9]"
10. "Misc. real [10]"
[misc integers]
1. "Work Coordinates [0-1=G92, 2=G15 Hxx's]"
2. "Absolute or Incremental [0=ABS, 1=INC]"
3. "Reference Return [0=G28, 1=G30]"
4. "Misc. integer [4]"
5. "Misc. integer [5]"
6. "Misc. integer [6]"
7. "Misc. integer [7]"
8. "Misc. integer [8]"
9. "Misc. integer [9]"
10. "Misc. integer [10]"
[simple drill]
1. "Drill/Counterbore"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. ""
8. ""
9. ""
10. ""
11. ""
[peck drill]
1. "eck drill"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
8. "Subsequent peck"
9. "eck clearance"
10. ""
11. ""
[chip break]
1. "Chip Break"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "eck clearance"
10. "Retract amount"
11. ""
[tap]
1. "Tap"
2. "Feed rate
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. ""
8. ""
9. ""
10. ""
11. ""
[bore1]
1. "Bore #1 (feed-out)"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. ""
8. ""
9. ""
10. ""
11. ""
[bore2]
1. "Bore #2 (stop spindle, rapid out)"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. ""
8. ""
9. ""
10. ""
11. ""
[misc1]
1. "Fine bore (shift)"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. ""
8. ""
9. ""
10. ""
11. "Shift"
[misc2]
1. "Misc. #2"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "eck clearance"
11. "Shift"
[drill cycle 9]
1. "Custom cycle 9"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "Peck clearance"
11. "Shift"
[drill cycle 10]
1. "Custom cycle 10"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "Peck clearance"
11. "Shift"
[drill cycle 11]
1. "Custom cycle 11"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "Peck clearance"
11. "Shift"
[drill cycle 12]
1. "Custom cycle 12"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "Peck clearance"
11. "Shift"
[drill cycle 13]
1. "Custom cycle 13"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "Peck clearance"
11. "Shift"
[drill cycle 14]
1. "Custom cycle 14"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "Peck clearance"
11. "Shift"
[drill cycle 15]
1. "Custom cycle 15"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "Peck clearance"
11. "Shift"
[drill cycle 16]
1. "Custom cycle 16"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "Peck clearance"
11. "Shift"
[drill cycle 17]
1. "Custom cycle 17"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "Peck clearance"
11. "Shift"
[drill cycle 18]
1. "Custom cycle 18"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "Peck clearance"
11. "Shift"
[drill cycle 19]
1. "Custom cycle 19"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "Peck clearance"
11. "Shift"
[drill cycle 20]
1. "Custom cycle 20"
2. "Feed rate"
3. "Dwell"
4. "Clearance..."
5. "Retract..."
6. "Depth..."
7. "1st peck"
9. "Peck clearance"
11. "Shift"
[drill_parm_dlg]
1. "Drill parameters"
10. ""
12. "clearance"
19. "Custom..."
[drill cycle descriptions]
1. "Simple drill - no peck"
2. "Peck drill - full retract"
3. "Chip break - incremental retract"
4. "Tapping - feed in, reverse spindle - feed out"
5. "Boring #1 - feed out"
6. "Boring #2 - stop spindle - rapid out"
7. "Misc #1 Drill"
8. "Misc #2 Drill"
9. "Custom drill cycle #9"
10. "Custom drill cycle #10"
11. "Custom drill cycle #11"
12. "Custom drill cycle #12"
13. "Custom drill cycle #13"
14. "Custom drill cycle #14"
15. "Custom drill cycle #15"
16. "Custom drill cycle #16"
17. "Custom drill cycle #17"
18. "Custom drill cycle #18"
19. "Custom drill cycle #19"
20. "Custom drill cycle #20"
31. "5 axis"
[drill custom param 1]
1. "1-Drill parameter #1"
2. "1-Drill parameter #2"
3. "1-Drill parameter #3"
4. "1-Drill parameter #4"
5. "1-Drill parameter #5"
6. "1-Drill parameter #6"
7. "1-Drill parameter #7"
8. "1-Drill parameter #8"
9. "1-Drill parameter #9"
10. "1-Drill parameter #10"
11. "Custom Drill Parameters 1"
[drill custom param 2]
1. "2-Drill parameter #1"
2. "2-Drill parameter #2"
3. "2-Drill parameter #3"
4. "2-Drill parameter #4"
5. "2-Drill parameter #5"
6. "2-Drill parameter #6"
7. "2-Drill parameter #7"
8. "2-Drill parameter #8"
9. "2-Drill parameter #9"
10. "2-Drill parameter #10"
11. "Custom Drill Parameters 2"
[drill custom param 3]
1. "3-Drill parameter #1"
2. "3-Drill parameter #2"
3. "3-Drill parameter #3"
4. "3-Drill parameter #4"
5. "3-Drill parameter #5"
6. "3-Drill parameter #6"
7. "3-Drill parameter #7"
8. "3-Drill parameter #8"
9. "3-Drill parameter #9"
10. "3-Drill parameter #10"
11. "Custom Drill Parameters 3"
[drill custom param 4]
1. "4-Drill parameter #1"
2. "4-Drill parameter #2"
3. "4-Drill parameter #3"
4. "4-Drill parameter #4"
5. "4-Drill parameter #5"
6. "4-Drill parameter #6"
7. "4-Drill parameter #7"
8. "4-Drill parameter #8"
9. "4-Drill parameter #9"
10. "4-Drill parameter #10"
11. "Custom Drill Parameters 4"
[drill custom param 5]
1. "5-Drill parameter #1"
2. "5-Drill parameter #2"
3. "5-Drill parameter #3"
4. "5-Drill parameter #4"
5. "5-Drill parameter #5"
6. "5-Drill parameter #6"
7. "5-Drill parameter #7"
8. "5-Drill parameter #8"
9. "5-Drill parameter #9"
10. "5-Drill parameter #10"
11. "Custom Drill Parameters 5"
[drill custom param 6]
1. "6-Drill parameter #1"
2. "6-Drill parameter #2"
3. "6-Drill parameter #3"
4. "6-Drill parameter #4"
5. "6-Drill parameter #5"
6. "6-Drill parameter #6"
7. "6-Drill parameter #7"
8. "6-Drill parameter #8"
9. "6-Drill parameter #9"
10. "6-Drill parameter #10"
11. "Custom Drill Parameters 6"
[drill custom param 7]
1. "7-Drill parameter #1"
2. "7-Drill parameter #2"
3. "7-Drill parameter #3"
4. "7-Drill parameter #4"
5. "7-Drill parameter #5"
6. "7-Drill parameter #6"
7. "7-Drill parameter #7"
8. "7-Drill parameter #8"
9. "7-Drill parameter #9"
10. "7-Drill parameter #10"
11. "Custom Drill Parameters 7"
[drill custom param 8]
1. "8-Drill parameter #1"
2. "8-Drill parameter #2"
3. "8-Drill parameter #3"
4. "8-Drill parameter #4"
5. "8-Drill parameter #5"
6. "8-Drill parameter #6"
7. "8-Drill parameter #7"
8. "8-Drill parameter #8"
9. "8-Drill parameter #9"
10. "8-Drill parameter #10"
11. "Custom Drill Parameters 8"
[drill custom param 9]
1. "9-Drill parameter #1"
2. "9-Drill parameter #2"
3. "9-Drill parameter #3"
4. "9-Drill parameter #4"
5. "9-Drill parameter #5"
6. "9-Drill parameter #6"
7. "9-Drill parameter #7"
8. "9-Drill parameter #8"
9. "9-Drill parameter #9"
10. "9-Drill parameter #10"
11. "Custom Drill Parameters 9"
[drill custom param 10]
1. "10-Drill parameter #1"
2. "10-Drill parameter #2"
3. "10-Drill parameter #3"
4. "10-Drill parameter #4"
5. "10-Drill parameter #5"
6. "10-Drill parameter #6"
7. "10-Drill parameter #7"
8. "10-Drill parameter #8"
9. "10-Drill parameter #9"
10. "10-Drill parameter #10"
11. "Custom Drill Parameters 10"
[drill custom param 11]
1. "11-Drill parameter #1"
2. "11-Drill parameter #2"
3. "11-Drill parameter #3"
4. "11-Drill parameter #4"
5. "11-Drill parameter #5"
6. "11-Drill parameter #6"
7. "11-Drill parameter #7"
8. "11-Drill parameter #8"
9. "11-Drill parameter #9"
10. "11-Drill parameter #10"
11. "Custom Drill Parameters 11"
[drill custom param 12]
1. "12-Drill parameter #1"
2. "12-Drill parameter #2"
3. "12-Drill parameter #3"
4. "12-Drill parameter #4"
5. "12-Drill parameter #5"
6. "12-Drill parameter #6"
7. "12-Drill parameter #7"
8. "12-Drill parameter #8"
9. "12-Drill parameter #9"
10. "12-Drill parameter #10"
11. "Custom Drill Parameters 12"
[drill custom param 13]
1. "13-Drill parameter #1"
2. "13-Drill parameter #2"
3. "13-Drill parameter #3"
4. "13-Drill parameter #4"
5. "13-Drill parameter #5"
6. "13-Drill parameter #6"
7. "13-Drill parameter #7"
8. "13-Drill parameter #8"
9. "13-Drill parameter #9"
10. "13-Drill parameter #10"
11. "Custom Drill Parameters 13"
[drill custom param 14]
1. "14-Drill parameter #1"
2. "14-Drill parameter #2"
3. "14-Drill parameter #3"
4. "14-Drill parameter #4"
5. "14-Drill parameter #5"
6. "14-Drill parameter #6"
7. "14-Drill parameter #7"
8. "14-Drill parameter #8"
9. "14-Drill parameter #9"
10. "14-Drill parameter #10"
11. "Custom Drill Parameters 14"
[drill custom param 15]
1. "15-Drill parameter #1"
2. "15-Drill parameter #2"
3. "15-Drill parameter #3"
4. "15-Drill parameter #4"
5. "15-Drill parameter #5"
6. "15-Drill parameter #6"
7. "15-Drill parameter #7"
8. "15-Drill parameter #8"
9. "15-Drill parameter #9"
10. "15-Drill parameter #10"
11. "Custom Drill Parameters 15"
[drill custom param 16]
1. "16-Drill parameter #1"
2. "16-Drill parameter #2"
3. "16-Drill parameter #3"
4. "16-Drill parameter #4"
5. "16-Drill parameter #5"
6. "16-Drill parameter #6"
7. "16-Drill parameter #7"
8. "16-Drill parameter #8"
9. "16-Drill parameter #9"
10. "16-Drill parameter #10"
11. "Custom Drill Parameters 16"
[drill custom param 17]
1. "17-Drill parameter #1"
2. "17-Drill parameter #2"
3. "17-Drill parameter #3"
4. "17-Drill parameter #4"
5. "17-Drill parameter #5"
6. "17-Drill parameter #6"
7. "17-Drill parameter #7"
8. "17-Drill parameter #8"
9. "17-Drill parameter #9"
10. "17-Drill parameter #10"
11. "Custom Drill Parameters 17"
[drill custom param 18]
1. "18-Drill parameter #1"
2. "18-Drill parameter #2"
3. "18-Drill parameter #3"
4. "18-Drill parameter #4"
5. "18-Drill parameter #5"
6. "18-Drill parameter #6"
7. "18-Drill parameter #7"
8. "18-Drill parameter #8"
9. "18-Drill parameter #9"
10. "18-Drill parameter #10"
11. "Custom Drill Parameters 18"
[drill custom param 19]
1. "19-Drill parameter #1"
2. "19-Drill parameter #2"
3. "19-Drill parameter #3"
4. "19-Drill parameter #4"
5. "19-Drill parameter #5"
6. "19-Drill parameter #6"
7. "19-Drill parameter #7"
8. "19-Drill parameter #8"
9. "19-Drill parameter #9"
10. "19-Drill parameter #10"
11. "Custom Drill Parameters 19"
[drill custom param 20]
1. "20-Drill parameter #1"
2. "20-Drill parameter #2"
3. "20-Drill parameter #3"
4. "20-Drill parameter #4"
5. "20-Drill parameter #5"
6. "20-Drill parameter #6"
7. "20-Drill parameter #7"
8. "20-Drill parameter #8"
9. "20-Drill parameter #9"
10. "20-Drill parameter #10"
11. "Custom Drill Parameters 20"
什么把这儿改一下以后就不用改了。谢谢。
发表于 2005-6-25 23:47:43 | 只看该作者
在上面的那里改呢?????????
发表于 2005-6-29 16:34:41 | 只看该作者
请高手指点,为什么我用等高精加工圆弧曲面时,后处理没有
一个R,全部被打断成点(在不用圆弧过虑的情况下)
发表于 2005-6-29 16:35:12 | 只看该作者
一个R,全部被打断成点(在不用圆弧过虑的情况下).
发表于 2005-7-1 16:50:41 | 只看该作者
在设置里改
GMT+8, 2025-4-20 06:19 , Processed in 0.035698 second(s), 11 queries , Gzip On, Redis On.
