查看: 16399|回复: 1
l两个要命的问题
发表于 2002-12-18 11:26:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大侠:
      小弟有两个问题请大家来帮忙:
       (1) 我用的是UG18,打印机是HP DesignJET 430打印机,请问怎样设置打印机,请详细说明,因为小弟实在是很笨!
       (2) 我用UG18 所做的Drafting在EXPORT 成DWG&DXF 后,用AutoCAD2002打开后,发觉不是多了很多线,就是少了很多线,请问有谁能解决此问题?我的dxfdwg.def文件内容如下:
!Common keywords
LOG_FILE =
MSG_MASK = VOLUMINOUS
DSP_MASK = VOLUMINOUS
!dxftoug or dwgtoug keywords
UNITS = metric
MAX_SPLINE_DEGREE = 3
UGI_DIM_IMPORT_FLAG = ASSORTED_DIMN
!ugtodxf or ugtodwg keywords
UGI_SOLID_EXPORT = FACET
ACAD_VERSION = R2000
UGI_CURVE_MASK = Points,Lines,Arcs,Conics,B-Curves,Silhouette Curves,Solid Edges on Drawings,All Solid Edges
UGI_SURF_MASK =
UGI_ANNOT_MASK = Dimensions,Notes,Labels,ID Symbols,Tolerances,Centerlines,Crosshatching,Draft Aid by Parts,Stand Alone Symbols,Symbol Fonts
UGI_STRUCT_MASK = Groups,Views,Drawings,Components,Reference Sets
UGI_SOLID_MASK =
UGI_DRAWING_NAMES =
UGI_USER_DEFINED_VIEWS =
BCRVD = 2
SURFU =1
SURFV =1
UGI_PROC_ASSEM = Use load_options.def options
UGI_COMP_FAIL = Abort if Load Fails
UGI_LOAD_COMP = Load Components
UGI_LOAD_VER = Load Exact Version
UGI_COMP_SUB = Do not Allow Substitution
UGI_LOAD_OPTION = Load From Assem Dir
UGI_SEARCH_DIRS =
VIEW_MODERASE_MODE = YES
ASSEMBLY_MAP=OFF
FILL_MODE=OFF
  我的E-MAIL是xiepeng_74@sina.com
发表于 2002-12-28 23:13:20 | 只看该作者
分层
GMT+8, 2025-4-28 18:35 , Processed in 0.019692 second(s), 12 queries , Gzip On, Redis On.
