查看: 16209|回复: 5
我的EMX装了怎么不能用啊!
发表于 2005-7-8 06:53:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
装了以后截面上左边菜单图表都出来了就是工具栏菜单上没有EMX进来,请指点啊
发表于 2005-7-8 10:14:09 | 只看该作者
没有正确安装。
发表于 2005-7-8 10:29:24 | 只看该作者
我的也是,是不是版本的问题
发表于 2005-7-8 11:51:36 | 只看该作者
倒!那怎么装啊?
发表于 2005-11-20 08:47:28 | 只看该作者
EMX不能正常运行,还需要将两个配置文件复制到PRO/E默认的启动目录中,打开EMX4。0安装目录下的(text),找到config.pro 和config.win两个文件,复制并粘贴在PRO/E 默认的启动目录中就可了
发表于 2005-11-21 19:42:24 | 只看该作者
只要你是按以下设置一下就可以了,不知各位有没有这项设置。
PTC Expert Moldbase Extension v4.0
Note: EMX is compatible with Pro/e 2001 and Wildfire Release. Make
      sure you read the setup notes in proe_loadpoint\emx40\docu\
      usascii\user\index.htm. Also, if you are using the ROR release
      of Wildfire then use our license since it has the missing options
      #210 in it.
1. Copy the folder "emx40" on the CD to you Pro/e loadpoint.
   E.g. C:\ptc\proe2001\emx40.
2. Open proe_loadpoint\emx40\text and edit the protk.dat. Set the paths
   to you installed path for following lines in the protk.dat file:
   E.g.   exec_file C:\Ptc\proeWildfire\emx40\i486_nt\emx40.dll
          text_dir  C:\Ptc\proeWildfire\emx40\text
3. Open proe_loadpoint\emx40\text and edit the config.pro. Change the
   config option (last line) "PROTKDAT" to your installed path:
   E.g.   PROTKDAT C:\Ptc\proeWildfire\emx40\text\protk.dat
4. Copy the config.pro and the config.win to you start directory
   or to C:\Ptc\proeWildfire\text directory.
5  Edit the ptc.dat in the crack direcory. Change 00-00-00-00-00-00 to
   your Host ID (Network card number and keep "-"). Run the keygen.bat
   and replace your existing ptc license.dat. You will need to rerun
   setup.bat in the proe_loadpoint\bin and edit and select our
   license file at the start command window.
GMT+8, 2025-4-28 15:19 , Processed in 0.025454 second(s), 12 queries , Gzip On, Redis On.
