查看: 15764|回复: 0
标题:寻找电机厂商 / 电工模具或厂商
发表于 2005-7-8 13:40:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
标题:寻找电机厂商 / 电工模具或厂商
Sourcing Manager in South China working on one project for
Motors, interested pls begin contact via email yuanrong168@yahoo.com.cn
1st P.O
Need standard general purpose 3 phase and single phase (with capacitors
and without) motors. They should be made according to DIN standards. We need
motors with frame size from 56 to 225 for 3 phase and from 71 to 100 for
single phase. Frames up to 132 should be aluminium, from 160 – from cast
iron.
Power range for these frame sizes is usually from 0,09kW to 37kW, depends
from manufacturer. Motors usually are made with 2,4,6 poles (speed
~3000,~1500,~1000 rpm respectively), voltage 230/400 or 400/690V, frequency
50 Hz. We require protection class IP55 Insulation class F (sometimes H, on
special request). We buy motors with flanges B3, B35, B5, B34a, B14a.
The primary reference – DIN standard, everything is there. I do not believe
that there exists any motor manufacturer that doesn’t know what B3 is. (海归论坛 www.haiguinet.com)
Motors should bear CE mark.
2. P.O
寻找模具高手厂商,能帮助本地化开发某电工产品,原为德国制造。
该电器开关为3个部分卡座,倒钩结合,无螺丝钉。可能类似Legrand 模式。
GMT+8, 2025-4-26 23:41 , Processed in 0.020076 second(s), 11 queries , Gzip On, Redis On.
