查看: 17709|回复: 3
急问3D lab vx1的显卡UG实体显示成碎片,咋办?
发表于 2005-7-19 15:17:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
谢谢!
发表于 2005-7-19 15:24:43 | 只看该作者
winxp中关掉写入合并,并调整硬件加速,再不行可能显卡不支持!
       在桌面右击,属性-〉设置-〉高级-〉疑难解答
发表于 2005-7-19 16:29:07 | 只看该作者
老问题。
做做好心:https://www.3dlabs.com/support/troubleshooting/ap-16.htm
If you are having problems when in shaded mode whilst using Unigraphics V18, the following amendment to your systems registry should resolve the problem:
Run "regedit" and browse to the HKEY_CURRENT_USER/Software/Unigraphics Solutions/UG/180/Visualisation folder in your registry. In this folder there should be a string which looks like "(computer name) (computer name):0.0 GLINT R3 PT configuration". Find this then double click it to bring up the Edit String window. In the Value data box, change all instances of the word "display" and replace it with the word "immediate".
发表于 2005-7-20 10:07:38 | 只看该作者
谢谢二位!我记得改过immediate的,现在又犯了,关掉写入合并现在好了,十分感谢!!
GMT+8, 2025-4-20 15:04 , Processed in 0.067257 second(s), 11 queries , Gzip On, Redis On.
