查看: 16496|回复: 2
请教一个很菜鸟的问题——怎么用vba画椭球体?
发表于 2005-7-26 22:46:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本人想通过AddRevolvedSolid命令实现,似乎这个命令只对直线和圆弧有效,对椭圆好像不行,望大虾指教
发表于 2005-7-27 13:41:45 | 只看该作者
可以先做成半个椭圆,形成面域之后在回转成椭球体。
发表于 2005-7-28 13:17:59 | 只看该作者
呵呵,谢了,昨天仔细研究了一下,终于搞定了
Public Sub AddMyEllipsoid(ellipsoid As EllipsoidModel)
    Dim majAxis(0 To 2) As Double
    Dim center(0 To 2) As Double
    Dim radRatio As Double
    Dim curves(0 To 1) As AcadEntity
    Dim regionObj As Variant
    Dim startpt(0 To 2) As Double
    Dim endpt(0 To 2) As Double
    center(0) = ellipsoid.cx: center(1) = ellipsoid.cy: center(2) = ellipsoid.cz
    majAxis(0) = ellipsoid.rx: majAxis(1) = 0: majAxis(2) = 0
    radRatio = ellipsoid.ry / ellipsoid.rx
    Set curves(0) = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
    curves(0).StartParameter = 0
    curves(0).EndParameter = 3.141592
    startpt(0) = ellipsoid.cx: startpt(1) = ellipsoid.cy: startpt(2) = ellipsoid.cz
    endpt(0) = ellipsoid.rx: endpt(1) = 0: endpt(2) = 0
    Set curves(1) = ThisDrawing.ModelSpace.AddLine(curves(0).StartPoint, curves(0).EndPoint)
    regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
    Set ModelObj = ThisDrawing.ModelSpace.AddRevolvedSolid(regionObj(0), startpt, endpt, 6.28)
End Sub
其中EllipsoidModel是个结构体
GMT+8, 2025-9-18 18:32 , Processed in 0.042059 second(s), 14 queries , Gzip On, Redis On.
