查看: 16427|回复: 2
请教UF_MODL_create_rect_slot的用法:
发表于 2005-7-31 16:18:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请那位大侠讲解一下UF_MODL_create_rect_slot的用法:
extern int UF_MODL_create_rect_slot (
double location[ ],
double tool_axis[ ],
double direction[ ],
char * width,
char * depth,
char * distance,
tag_t face_li,
tag_t face_t1,
tag_t face_t2,
tag_t * feature_tag );
double  location[ ] Input Rectangular slot location.
double  tool_axis[ ] Input Rectangular slot tool axis.
double  direction[ ] Input Rectangular slot direction.
char *  width Input Rectangular slot width.
char *  depth Input Rectangular slot depth.
char *  distance Input Rectangular slot distance.
tag_t  face_li Input Face for the RPO constraint.
tag_t  face_t1 Input Face for thru face 1.
tag_t  face_t2 Input Face for thru face 2.
tag_t *  feature_tag Output Feature object identifier of created rectangular slot
里面的location[ ],tool_axis[ ],direction[ ]怎么取得呀
发表于 2005-8-4 10:54:18 | 只看该作者
    double block_orig[3] = {0.0,0.0,0.0};
    char *block_len[3] = {"100","60","40"};
    tag_t blk_fea,blk_obj,*face_tag=NULL;
    int count,i;
    uf_list_p_t face_list;
    double location[3]={50,30,40}; //slot 的原点
        double tool_axis[ ]={0,0,1};//工具轴
        double direction[ ]={1,0,0};//方向
        char * width="15";
        char * depth="15";
        char * distance="40";
发表于 2005-8-4 15:43:59 | 只看该作者
谢谢kangkang兄
GMT+8, 2025-1-31 23:55 , Processed in 0.020861 second(s), 10 queries , Gzip On, Redis On.
