查看: 17700|回复: 3
谁有李军车的轮胎和地面普文件???
发表于 2005-8-1 23:11:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
谁有李军车的轮胎和地面普文件,可以传个我吗???谢谢!!!xiaogou2001.min@126.com
发表于 2005-9-16 16:29:11 | 只看该作者
可以自己编的,我编了 jeep_tire.tir 和  jeep_road.rdf , 可在ADAMS 中导入jeep_road.rdf时却出现 "无效METHOD" 的提示, 我也不知怎么回事, 求教各位高手!!!  (jeep_road.rdf 是按照李军书上的 , 拿记事本编写的)
发表于 2005-9-24 14:55:49 | 只看该作者
!   | ROAD DATA FILE |
!  Default road file - flat
METHOD
GENDATA
!  Conversion factors
X_SCALE
  1.0
Y_SCALE
  1.0
Z_SCALE
  1.0
!Road origin is located at the following global coordinates in the
!data set.
ORIGIN
0 0 0
UP
0,1,0
!Road coordinate system is oriented with respect to the global origin
!by the following transformation matrix.
ORIENTATION
1 0 0
0 1 0
0 0 1
!Coordinates for the node points on road
NODES
  1   200000 0 -20000
  2  -500000 0 -20000
  3   200000 0 400000
  4  -500000 0 400000
!Connectivity of node points defining the triangular element
ELEMENTS
  1    2     3    1.0    1.0
  2    3     4    1.0    1.0
!   | TIRE_PROPERTY_FILE |
MODEL=
ANALYTICAL
!  ANALYTICAL PARAMETERS BLOCK
R1      (undeflected outside tire radius)
  1  375
R2      (idealized toroidal cross section carcass radius)
  1 107.5
CN      (vertical stiffness at zero deflection)
  1   261.3
CSLIP   (longitudinal stiffness at zero slip ratio)
  1  30000
CALPHA  (lateral stiffness due to slip angle at zero slip angle)
  0.01745  46000
CGAMMA  (lateral stiffness due to inclination angle at zero inclination angle)
  0.01745  4000
CRR  (rolling resistance moment)
  1.00  5.625
RDR (vertical damping ratio)
  0.75
U0  (maximum friction coefficient, friction coefficient at zero slip)
  0.94
U1  (minimum friction coefficient, friction coefficient at full slip)
  0.75
楼上的,你的轮胎文件的文件类型是不是错了啊?
jeep_tire.tpf
发表于 2005-9-24 21:34:26 | 只看该作者
李军书上轮胎文件的类型是 .tpf  , 但我在MSC.ADAMS 2005 中导入轮胎文件时要求的是.tir 文件, 所以我把扩展名改成了.tir . 其实在软件的安装目录(MSC.Software\MSC.ADAMS\2005\solver\atire\roads.tbl)下也有自带的轮胎文件和路面谱文件,我选用了其中的一个,当时效果挺好也没出错, 但可惜最终整车模型出来后,还是没防真成功
GMT+8, 2025-4-21 02:13 , Processed in 0.023307 second(s), 12 queries , Gzip On, Redis On.
