查看: 15906|回复: 1
应力分析错误
发表于 2005-8-2 18:14:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
** WARNING ** Solution iteration limit reached before convergence
              Solution error =      1.0000 C
** ERROR 701010 ** Cooling analysis has not converged
** ERROR 99986 ** Invalid dimension, element    9433
** ERROR 99986 ** Invalid dimension, element    9434
** ERROR 99986 ** Invalid dimension, element    9435
** ERROR 99780 ** Zero diameter/thickness for element    2255 . An element
                  should have a non-zero value for the diameter or
                  thickness associated with it. Identify this element and
                  use an appropriate value for the diameter or thickness,
                  re-mesh the part, and re-run the analysis.
** ERROR 99780 ** Zero diameter/thickness for element    2256 . An element
** ERROR 99780 ** Zero diameter/thickness for element    2257 . An element
请楼主帮忙,解决,谢谢
发表于 2005-8-3 15:00:01 | 只看该作者
提示很多网格有问题。建议把网格修一下再试。
GMT+8, 2025-4-23 15:46 , Processed in 0.020407 second(s), 11 queries , Gzip On, Redis On.
