查看: 16569|回复: 1
请教各位柔性体仿真问题
发表于 2005-8-8 17:36:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我在对一个构件全部为柔性体的两自由度机构仿真时,其中一个驱动为:30d*time ,另一个为40d*time时可以仿真,但是当把第一个驱动改为3000d*time,第二个改为:3600d*time的时候,出现错误提示,无法仿真下去。求解器选用ABAM,Maxit=50.下面是错误提示:WARNING: The value 50 was specified for the BDFPAR/ CRMAXIT argument. Since the corrector algorithm in the BDF methods should converge very rapidly,such a high number of iterations should not be necessary and may cause an excessive consumption of cpu time.
WARNING: After 10 corrections to the state vector, the iterative
algorithm has not reconciled the displacement coordinates with the constraint equations to within the specified tolerance of 2.50E-04 .
FAULT: DDEABM: AN APPARENT INFINITE LOOP HAS BEEN DETECTED. YOU HAVE MADE REPEATED CALLS AT T = 6.86966E-02 AND INTEGRATION HAS NOT ADVANCED.CHECK THE WAY YOU HAVE SET PARAMETERS FOR THE CALL TO THE CODE,
PARTICULARLY INFO(1). .
ERROR: Program Fault encountered in Solver.
到底在哪里出了错误。请各位高人指点,
发表于 2006-6-26 00:15:05 | 只看该作者
给的驱动数值太大,求解器当然无法计算!
GMT+8, 2025-4-23 05:26 , Processed in 0.023846 second(s), 11 queries , Gzip On, Redis On.
