查看: 17009|回复: 4
问T1
发表于 2002-12-25 08:09:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
出现如图警报,查其产生的ACC文件,内容如下?
Accuracy Conflict Report For Assembly ROD.
1. Models in the list may have accuracy set to absolute or relative accuracy.
2. When the model's accuracy is relative, an absolute accuracy value
is calculated based on the model's relative accuracy.
3. The following list shows the absolute accuracy value for each model
that is actually used in geometry calculations.
        Generic Model Name           Abs Accuracy Value  Unit Name
ROD.ASM                               0.052543117       in
ROD_REF.PRT                           0.020201100       in
ROD_WP.PRT                            0.055392369       in
如何解决?
发表于 2002-12-25 09:58:06 | 只看该作者
很簡單!上面顯示這三個零件的精度不相同,把其全部改成相同的即可!
发表于 2002-12-25 10:59:38 | 只看该作者
问T是我不知道如何改,意思我明白
发表于 2002-12-25 11:07:06 | 只看该作者
  在CONFIG。PRO 文件里加上以下几行:
  default_abs_accuracy 0.005
enable_absolute_accuracy yes
enable_assembly_accuracy yes
   然后再重新起动PROE ,在菜单的SET UP  Accuracy 里搞掂!
发表于 2002-12-25 11:37:37 | 只看该作者
谢谢
GMT+8, 2025-4-24 20:04 , Processed in 0.021615 second(s), 11 queries , Gzip On, Redis On.
