查看: 17920|回复: 2
CAA中怎样得到工程图上点的坐标?
发表于 2005-9-5 11:00:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我在工程图中生成了一个点,然后想用鼠标点击选择,得到点的坐标,可是总出问题得不到,劳烦各位帮我看看,谢了~~
CATFeatureImportAgent * _ObjectAgent;
_ObjectAgent  = new CATFeatureImportAgent ( "ointAgent", NULL, NULL, NULL, NULL, NULL) ;
     _ObjectAgent -> SetElementType ( "CATI2DPoint"  );
     _ObjectAgent -> SetBehavior      ( CATDlgEngWithPrevaluation | CATDlgEngAcceptOnPrevaluate | CATDlgEngWithUndo | CATDlgEngWithPSOHSO | CATDlgEngOneShot);
     _ObjectAgent -> SetAgentBehavior ( MfPermanentBody  | MfLastFeatureSupport | MfRelimitedFeaturization );
     // Point selection state
     CATDialogState *pState1= GetInitialState("Select a point ");
     pState1 -> AddDialogAgent ( _ObjectAgent   );
     // Transitions
     AddTransition ( pState1 , NULL ,
                     IsOutputSetCondition ( _ObjectAgent ) ,
                     Action ( ( ActionMethod ) [$DmCmd::GetPoint ) )]
CATBoolean DmCmd::GetPoint( void *data )
      CATPathElement* iPath=NULL;
      iPath = _ObjectAgent->GetValue();
      CATBaseUnknown * pObject2D = _ObjectAgent->GetElementValue(iPath);
      CATMathPoint2D * pPoint = (CATMathPoint2D *) pObject2D;
      x = pPoint->GetX();
      y = pPoint->GetY();
      _ObjectAgent -> InitializeAcquisition();
     return TRUE;
发表于 2005-9-5 22:38:26 | 只看该作者
已解决```
发表于 2005-9-9 16:57:17 | 只看该作者
怎样解决的呀,能否贴出来,共同学习呀?
GMT+8, 2025-7-8 14:27 , Processed in 0.025350 second(s), 11 queries , Gzip On, Redis On.
