查看: 15937|回复: 1
这是个什么CAM软件的后置处理?
发表于 2005-9-23 19:11:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
formAT (COORDINATES) XOLD YOLD ZOLD DXCENTER DYCENTER;
formAT (COORDINATES) DZCENTER ZINIT CLEAR DEPTH XHOME;
formAT (COORDINATES) YHOME ZHOME XFIRSTORIGIN YFIRSTORIGIN ZFIRSTORIGIN;
formAT (COORDINATES) ORIGOLDI ORIGOLDJ ORIGOLDK;
formAT (SEQUENCING) SEQ SUBSEQ;
formAT (TOOL) CUTTERCOMP FIRSTTOOL LASTTOOL;
formAT (USER_1) CURRSUBNUM SUB_NUMBER;
formAT (USER_2) FLAGSUB FLAGSEQ FLAGSPIN FIRSTORIGINCHANGE FLAGERROR;
formAT (USER_2) FLAGROTMAC YES NO;
INTERACTION (CHARACTER) "SEQUENCING<Y/N>" NUMYN = "N";
INTERACTION (CHARACTER) "SUBROUTINES<Y/N>" SUB = "N";
INTERACTION (SEQUENCING) "SEQUENC-START" SEQSTART = 10;
INTERACTION (SEQUENCING) "SEQUENC-INCR." SEQINCR = 2;
INTERACTION (TOOL) "DIACOMP=TOOL+<xx>" DIACOMP = 50;
INTERACTION (USER_1) "MAIN-PROGRAM-NUMBER" MAINNUM = 10;
INTERACTION (USER_1) "TOOL-CHANGE-PROGRAM" CHANGETOOL = 8000;
INTERACTION (USER_1) "SUB-PROGRAM-NUMBER" STARTSUBNUM = 1000;
NON_MODAL ALL_VAR;
MODAL CLEAR DEPTH X_CURPOS Y_CURPOS Z_CURPOS;
MODAL LIN_MOV CIRC_MOV MCH_FEED SPIN_SPEED SPIN_DIR;
MODAL MCH_COOL MCH_DWELL CUTCOM_ON CUTCOM_OFF CYC_DEPTH;
MODAL CYC_PECK CYC_DWELL CYC_RETR CYC_CLEAR;
IDENTICAL X_CURPOS X_ENDPT;
IDENTICAL Y_CURPOS Y_ENDPT;
NEW_LINE_IS $ ;
     IF_SET (FlagSeq _EQ_ NO)
OUTPUT \J ;
     ELSE
IF_SET (FlagSub _EQ_ NO)
   OUTPUT \J "N" Seq ;
   Seq = Seq + SeqIncr ;
ELSE
   OUTPUT \J "N" SubSeq ;
   SubSeq = SubSeq + SeqIncr ;
END_IF ;
     END_IF ;
BEGINNING OF TAPE:
*{{ GPP range check
*}} GPP range check
     YES              = 1 ;
     NO               = 0 ;
     Seq              = SeqStart ;
     FlagSeq = NO ;
     FlagSub = NO ;
     IF_SET (NumYN _EQ_ "y") FlagSeq = YES ; END_IF ;
     IF_SET (NumYN _EQ_ "Y") FlagSeq = YES ; END_IF ;
     IF_SET (Sub   _EQ_ "y") Sub     = "Y" ; END_IF ;
     IF_SET (Sub   _EQ_ "Y")
SET_OFF NO_SUBROUT ;
     ELSE
SET_ON  NO_SUBROUT ;
     END_IF ;
*-----Unit matrix (MUST be input in this order !!!)
     ROT_MAT1   = 1.0 ; ROT_MAT2   = 0.0 ; ROT_MAT3   = 0.0 ;
     ROT_MAT4   = 0.0 ; ROT_MAT5   = 1.0 ; ROT_MAT6   = 0.0 ;
     ROT_MAT7   = 0.0 ; ROT_MAT8   = 0.0 ; ROT_MAT9   = 1.0 ;
*-----shift all data according to the MCHINE ZERO indicated by the
*     user in the POSTPR interaction
     TRANS_MATX = 0 - X_MACH  ;
     TRANS_MATY = 0 - Y_MACH  ;
     TRANS_MATZ = 0 - Z_MACH  ;
*-----shift the HOME according to the MCHINE ZERO indicated by the
     Xhome = X_HOME - X_MACH  ;
     Yhome = Y_HOME - Y_MACH  ;
     Zhome = Z_HOME - Z_MACH  ;
*-----tool location is HOME
     Xold = X_HOME ;
     Yold = Y_HOME ;
     Zold = Z_HOME ;
*-----For 1st ORIGIN CHANGE
     FirstOriginChange = YES ;
     MCH_FEED   = 9999 ;
*-----output
     IF_SET (FlagSeq _EQ_ YES )
OUTPUT "O" MainNum  ;
     ELSE
     END_IF ;
*--For the first origin change
  ORIGOLDI=0 ; ORIGOLDJ=0 ; ORIGOLDK=1 ;
  flagrotmac = no ;
BEGINNING OF PROC:
*{{ GPP range check
*}} GPP range check
     KEEP   PROC_NAME ;
     SET_ON MCH_COOL ;
     FlagSub = NO ;
     SubSeq  = SeqStart ;
END OF file:
     OUTPUT $ "M09 " ;
     OUTPUT $ "M05 " ;
     OUTPUT $ "M30 " ;
     ELSE
         OUTPUT $ "M09 " ;
         OUTPUT $ "M05 " ;
         OUTPUT $ "M30 " ;
     END_IF ;
FEED:
*{{ GPP range check
*}} GPP range check
     KEEP MCH_FEED ;
SPIN:
*{{ GPP range check
*}} GPP range check
     KEEP SPIN_SPEED ;
COOLANT:
*{{ GPP range check
*}} GPP range check
     KEEP MCH_COOL ;
DWELL:
*{{ GPP range check
*}} GPP range check
     KEEP MCH_DWELL ;
CUTTER COMPENSATION:
*{{ GPP range check
*}} GPP range check
     KEEP  CUTCOM_ON ;
CUTTER COMPENSATION: COFF:
*{{ GPP range check
*}} GPP range check
     KEEP  CUTCOM_OFF ;
TOOL CHANGE: FIRST:
*{{ GPP range check
*}} GPP range check
     SET_ON  SPIN_SPEED SPIN_DIR ;
*-----save first tool number
     FirstTool = CURR_TOOL ;
     LastTool  = CURR_TOOL ;
*-----tool cutter compensation register number
     CutterComp = CURR_TOOL +  DiaComp ;
*-----assuming 1st tool is in the spindle, there is no need
*     for tool change)
     OUTPUT $ "G91 G28 Z0 " ;
*-----more then one tool in this run of the Post Processor
     IF_SET (NEXT_TOOL _NE_ CURR_TOOL)
     OUTPUT $ "T" CURR_TOOL " T0 M06 " ;
     END_IF ;
*-----standard tool change commands. (assuming 1st tool is in
     OUTPUT $ "G90 G00 G54 X0. Y0." ;
     OUTPUT $ "G43 H" CURR_TOOL " Z" Zhome ;
     OUTPUT $ "S" SPIN_SPEED " " SPIN_DIR ;
TOOL CHANGE:
*{{ GPP range check
*}} GPP range check
*-----tool change command (by using an internal tool change
*     subroutine)
     OUTPUT $ "M09 " ;
     OUTPUT $ "M05 " ;
     OUTPUT $ "G90 G00 G54  " ;
TOOL CHANGE: LAST:
*{{ GPP range check
*}} GPP range check
*-----save last tool number
     OUTPUT $ "M09 " ;
     OUTPUT $ "M05 " ;
*-----the last tool is the same as the first tool
     OUTPUT $ "T" CURR_TOOL " T0 M06"  ;
     END_IF ;
LINEAR MOTION: FAST:
*{{ GPP range check
*}} GPP range check
     FlagSpin = NO ;
     IF_SET (SPIN_SPEED) FlagSpin = YES ; END_IF ;
     IF_SET (SPIN_DIR)   FlagSpin = YES ; END_IF ;
     IF_SET (FlagSpin _EQ_ YES)
OUTPUT $ " S" SPIN_SPEED " " SPIN_DIR ;
     END_IF ;
     OUTPUT $ ;
     IF_SET (LIN_MOV)  OUTPUT     LIN_MOV   ; END_IF ;
     IF_SET (X_CURPOS) OUTPUT "X" X_CURPOS ; END_IF ;
     IF_SET (Y_CURPOS) OUTPUT "Y" Y_CURPOS ; END_IF ;
     IF_SET (MCH_COOL) OUTPUT  "" MCH_COOL ; END_IF ;
     IF_SET (Z_CURPOS) OUTPUT $ "Z" Z_CURPOS ; END_IF ;
     SET_ON CIRC_MOV ;
     Xold = X_CURPOS ;
     Yold = Y_CURPOS ;
     Zold = Z_CURPOS ;
LINEAR MOTION:
*{{ GPP range check
*}} GPP range check
     FlagSpin = NO ;
     END_IF ;
     OUTPUT $ ;
     IF_SET (CUTCOM_ON)  OUTPUT     CUTCOM_ON " D" CutterComp ; END_IF ;
     IF_SET (CUTCOM_OFF) OUTPUT     CUTCOM_OFF ; END_IF ;
     IF_SET (Z_CURPOS)   OUTPUT "Z" Z_CURPOS   ; END_IF ;
     IF_SET (MCH_FEED)   OUTPUT "F" MCH_FEED   ; END_IF ;
     SET_ON CIRC_MOV ;
     Xold = X_CURPOS ;
     Yold = Y_CURPOS ;
     Zold = Z_CURPOS ;
CIRCULAR MOTION:
*{{ GPP range check
*}} GPP range check
     FlagSpin = NO ;
     END_IF ;
     DXcenter = X_CENTER - Xold ;
     DYcenter = Y_CENTER - Yold ;
     DZcenter = Z_CENTER - Zold ;
     OUTPUT $ ;
     IF_SET (CIRC_MOV)          OUTPUT     CIRC_MOV  ; END_IF ;
     IF_SET (X_CURPOS)          OUTPUT "X" X_ENDPT  ; END_IF ;
     IF_SET (Y_CURPOS)          OUTPUT "Y" Y_ENDPT  ; END_IF ;
     IF_SET (Z_CURPOS)          OUTPUT "Z" Z_ENDPT  ; END_IF ;
     IF_SET (RADIUS_)           OUTPUT "R"  RADIUS_ ; END_IF ;
     SET_ON LIN_MOV ;
     Xold = X_CURPOS ;
     Yold = Y_CURPOS ;
     Zold = Z_CURPOS ;
SUBROUTINE CALL:
     CurrSubNum = SUB_NUMBER + StartSubNum ;
     OUTPUT $ "M98 P" CurrSubNum  ;
BEGINNING OF SUB:
*{{ GPP range check
*}} GPP range check
     SET_ON  MCH_FEED MCH_COOL LIN_MOV CIRC_MOV ;
     FlagSub = YES ;
     OUTPUT \J " " ;
     IF_SET (FlagSeq _EQ_ YES)
OUTPUT \J "O" CurrSubNum ;
     ELSE
     END_IF ;
END OF SUB:
     OUTPUT $  "M99" ;
     FlagSub = NO ;
SUBROUTINE RETURN:
*{{ GPP range check
*}} GPP range check
     SET_ON LIN_MOV CIRC_MOV X_CURPOS Y_CURPOS Z_CURPOS;
发表于 2005-9-23 20:13:07 | 只看该作者
CIMATRON GPP POST
GMT+8, 2025-4-22 09:55 , Processed in 0.023194 second(s), 11 queries , Gzip On, Redis On.
