查看: 16248|回复: 3
在UG NX中更改設置如何做到?
发表于 2003-1-2 10:06:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在UG NX中,現在對其实体的顏色進行更改後,
下次啟動UG時,不能保存自己所設定的,
不知如何才能做到采用自己的一種設置?
可不可以在源文件中改?如何更改?謝謝~~
发表于 2003-1-2 18:40:03 | 只看该作者
我也想知道呀,谁会快说啦,:-P
发表于 2003-1-3 11:26:09 | 只看该作者
刚刚开始学UG,还是18版的。这方面琢磨了一个方法不知到合不合用:
修改UGII下的UG_METRIC.DEF ,下面几行是控制其各个元素的颜色的:
! Valid color options are: [1-216]
! (  Pre-V17 values were:    blue (1), green (2), cyan (3), red (4), magenta (5),
!                            yellow (6), white (7), olive (8), pink (9), brown (10),
!                            orange (11), purple (12), dark-red (13), aquamarine (14), gray (15) )
! Valid line font options are: [solid, dashed, phantom, centerline, dotted,
!                               long_dashed, dotted_dashed]
! Valid width options are: [thin, normal, thick]
!下面是控制物体颜色
UG_objectColor:   2
UG_objectLineFont:   solid
UG_objectWidth:   normal
! Type Specific Color, Line Font and Width Assignments
! The following settings control the object creation color, line font and width
! of specific types of objects.
! Valid color options are: [default, 1-216]
! Valid line font options are: [default, solid, dashed, phantom, centerline,
!                               dotted, long_dashed, dotted_dashed]
! Valid width options are: [default, thin, normal, thick]
! NOTE: The 'default' option means that the default setting, the setting
!       associated with the object<Color|LineFont|Width> customer default, is
!       to be used.
! Point Settings
!     (Note: line font and width settings are invalid for this type)
!点的颜色,default是默认的颜色,可以用数字替换,1表示兰色
UG_pointColor:     default
! Line Settings
!线的颜色
UG_lineColor:     10
UG_lineFont:     default
UG_lineWidth:     default
!圆弧的颜色
! Arc Settings
UG_arcColor:     10
UG_arcFont:     default
UG_arcWidth:     default
! Conic Settings  (i.e. Ellipse, Hyperbola, Parabola)
!二次曲线的颜色
UG_conicColor:     10
UG_conicFont:     default
UG_conicWidth:     default
! Spline Settings
!样条曲线
UG_splineColor:   10
UG_splineFont:     default
UG_splineWidth:   default
! Coordinate System Settings
!坐标系
UG_csysColor:     7
! Solid Body Settings
!实体颜色
UG_solidBodyColor:   7
UG_solidBodyFont:   default
UG_solidBodyWidth:   default
! Sheet Body Settings
!片体颜色
UG_sheetBodyColor:   5
UG_sheetBodyFont:   default
UG_sheetBodyWidth:   default
! Plane, Datum Plane and Datum Axis Settings
!     (Note: line font and width settings are invalid for these types)
!参考面
UG_planeAndDatumColor:  14
! System Color - Controls the default system color, which governs the color
!     of view names and borders, the WCS, the grid, and temporarily
!     displayed items such as spline vertices, knotpoints, conehead
!     vectors, asterisks in the Point Subfunction, etc.
!                Also controls the color used for highlighting during selection
!  PreSelection Color - Controls the color used for pre-selection highlighting.
! Handles Color - This is the color used for the display of all handles.
!系统颜色,及预选颜色
UG_systemColor:    12
UG_preSelectionColor:   5
UG_handlesColor:        6
发表于 2003-1-13 12:55:51 | 只看该作者
那Preferences里的参数怎么设置,比如加工时,我想两个刀路产生之间可以自动接下去,而不要打那么多钩
GMT+8, 2025-4-26 09:35 , Processed in 0.021539 second(s), 13 queries , Gzip On, Redis On.
