查看: 22374|回复: 13
【求助】如何把PROE的模型输入MOLDFLOW中。
发表于 2002-3-13 09:18:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
MOLDFLOW倒底有几个版本呀。好像ISO版的有四百多M。初来乍到希望朋友们多多关照。
发表于 2002-3-13 10:01:00 | 只看该作者
moldflow有mpi,mpa等,mpi用得较多,现在最高版本是3.0,好像还没有iso的,2.0版的有iso,是有400多M
proe输入moldflow一般用stl格式。
发表于 2002-3-13 11:25:46 | 只看该作者
是直接就可以传进去了吗?为何我在输入指令下选PREO的PART文件什么都没有呀。
一般社会上用的都是MPI还是MPA啊!!
大家谁有技术资料呀。我想买一点看看。光看帮助太累了呀。
发表于 2002-3-14 09:14:29 | 只看该作者
一般不用proe的part格式,你在proe下另存为*.stl即可。
注塑分析一般用的都是MPI
技术资料一般也都是E文的.
发表于 2002-3-15 09:11:18 | 只看该作者
谢谢这位大哥。MPI正在学习过程中有不懂之处还望老兄今后多多指点。ygdq@163.com
头像被屏蔽
发表于 2002-3-15 22:42:03 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2002-3-21 23:34:55 | 只看该作者
好象Moldflow也出了一个Moldflow Desgin Link(MDL)的。就是专门为MPI,MPA提供文档转化插口的软件,现在好象有3.0了的。不妨试试。
Release Notes: Moldflow Design Link 3.0
Moldflow Design Link 3.0 (MDL 3.0) provides a geometry data translation interface between Moldflow’s range of simulation products and leading CAD systems using standard file formats such as IGES, STEP, Parasolid, and Pro/ENGINEER[$reg] part files. MDL 3.0 can be used to import CAD model geometry directly into both Moldflow Plastics Advisers[$#8482] (MPA[$#8482]) and Moldflow Plastics Insight[$#8482] (MPI[$#8482]).
Enhancements
New in MDL 3.0 is an option to directly import native Pro/ENGINEER part files without the need for a separate Pro/ENGINEER license.
There are 2 versions available for MDL 3.0:
MDL/Parasolid – for the import of Parasolid, IGES, and STEP files
MDL/Pro/ENGINEER – for the import of Pro/ENGINEER part files, IGES, and STEP files
Integration with Moldflow Plastics Insight 3.0
MPI 3.0 and MPI 3.0 Revision 1
These releases are integrated with and support both MDL 2.0 and MDL 3.0.
Imported geometry is now represented in the new MPI/Synergy pre- and post-processor as trimmed NURBS surfaces.  These surfaces can be independently viewed, grouped, or meshed.  NURBS surfaces are supported by the IGES, STEP, Parasolid and Pro/ENGINEER file formats.
Integration with Moldflow Plastics Advisers 5.0
MPA 5.0 is currently integrated with MDL 3.0.
Usage from the command line
Input arguments
Argument
  Description
-i filename
  sets the input model
-o filename
  sets the output model
-k kernel
  sets the kernel (parasolid/parametric/moldflow)
-log filename
  set optional log file
-r on/off
  remesh mode on/off
-t on/off
  translate only on/off
-m mesher
  selects mesher (mpg/cm2k)
-input filename
  keyword input file
  -register
  locks current implementation of MDL to this path
Supported file types
Parasolid Kernel: X_T, X_B, STEP, IGES
Pro/ENGINEER Kernel: PRT, STEP, IGES
CAD System Issues
Limitation:
Pro/ENGINEER part  files (*.prt) are usually versioned, that is, there is an extension after the .prt extension (*.prt.1, *.prt.2 etc ). MPI 3.0, MPI 3.0 Revision 1, and MPA 5.0 currently do not support this type of file extension.  This is scheduled as an enhancement request for the future revisions in each product line.
Solution:
Rename the file to remove the version extension, for example, "model1.prt.1" would be renamed as "model1.prt".
Troubleshooting
Problem:
Previous Alpha versions of MDL 3.0 may have left some temporary files in the ./CDALIB directory used when translating STEP files with the Parasolid kernel. These usually arise from killing the MDL 3.0 job before it has properly finished. If this directory has not been deleted correctly then STEP file transfers will not work in MPI 3.0.
Solution:
Delete the ./CDALIB directory and all its contents. This is safe to do as all files in this directory are temporary files created at run time.
发表于 2002-6-27 10:27:05 | 只看该作者
能否讲一下iso的是什么意思啊,为什么那么大啊,和非iso的有和区别啊?
发表于 2002-7-29 08:58:37 | 只看该作者
上述接口对CATIA 转换出来的文件好象不太理想,也可能是我用CATIA还不精!
发表于 2002-8-8 15:44:41 | 只看该作者
我喜欢用fem(很久不用Moldflow,记不清)格式,直接输入转化网格。个人感觉1。0版最准确
GMT+8, 2025-4-18 03:22 , Processed in 0.031662 second(s), 14 queries , Gzip On, Redis On.
