查看: 15726|回复: 0
大家谁有COSMOS的插件阿?
 关闭 [复制链接]
发表于 2005-10-9 11:45:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我需要下载,可是找不到阿?
机子上装的是sw2005,下了一个cosmos2004可是装上以后不成。以下是CRACK里面的说明:
1. Run setup and at the Cosmos License information select the
   "Set Port and Host Name.." button. Enter 6666 in the first
   field and you computer name in second field. Select all option
   for installation when prompted.
2. Open the license.dat in the crack directory and change "host"
   on the first line to your computer name. Copy the license.dat
   to x:\COSMOS Application\License\Flexlm.
3. Run LMTools in x:\COSMOS Application\License\Flexlm directory
   and manually setup Flexlm services for Cosmos.
4. Set your Flexlm License Environment:
   LM_LICENSE_FILE = 6666@host  (Host being your computer name)
5. Reboot and you are ready.
第三和四部不知道如何实现?
请求回复。
GMT+8, 2025-4-28 18:20 , Processed in 0.020949 second(s), 12 queries , Gzip On, Redis On.
