查看: 15457|回复: 0
the ugnx problem,why???
发表于 2003-1-13 21:18:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
in the UGNX
some problem about the solid display often occur,
1, if you use the command "mirror feature"and the command"rectanguar array" together,the solid can't display,why?
2,completing modify ,some error occur when the feature udating,and there is not wrong in the feature ? why
l
GMT+8, 2025-2-27 01:44 , Processed in 0.023214 second(s), 11 queries , Gzip On, Redis On.
