查看: 16166|回复: 9
emx4.0好不容易装上,却不能用
发表于 2005-11-17 21:00:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
pro2001装上emx4.0却加载不上模架,路过的朋友给个提示
发表于 2005-11-17 22:14:46 | 只看该作者
2001的是安不好EMX4.0的安上了也不好用的这是用在2.0的上就很好用你可以去安一下
发表于 2005-11-18 12:25:28 | 只看该作者
我的装在2.0上也不能用啊,说error when opeing uci_file d:\\\\\\\\
那位老大能告诉我这是怎么回事啊
发表于 2005-11-18 13:35:41 | 只看该作者
EMX4。0不管是挂在proe2001上面,还是proe2。0上面都可以用的。
只要你是按以下设置一下就可以了,不知各位有没有这项设置。
PTC Expert Moldbase Extension v4.0
Note: EMX is compatible with Pro/e 2001 and Wildfire Release. Make
      sure you read the setup notes in proe_loadpoint\emx40\docu\
      usascii\user\index.htm. Also, if you are using the ROR release
      of Wildfire then use our license since it has the missing options
      #210 in it.
1. Copy the folder "emx40" on the CD to you Pro/e loadpoint.
   E.g. C:\ptc\proe2001\emx40.
2. Open proe_loadpoint\emx40\text and edit the protk.dat. Set the paths
   to you installed path for following lines in the protk.dat file:
   E.g.   exec_file C:\Ptc\proeWildfire\emx40\i486_nt\emx40.dll
          text_dir  C:\Ptc\proeWildfire\emx40\text
3. Open proe_loadpoint\emx40\text and edit the config.pro. Change the
   config option (last line) "PROTKDAT" to your installed path:
   E.g.   PROTKDAT C:\Ptc\proeWildfire\emx40\text\protk.dat
4. Copy the config.pro and the config.win to you start directory
   or to C:\Ptc\proeWildfire\text directory.
5  Edit the ptc.dat in the crack direcory. Change 00-00-00-00-00-00 to
   your Host ID (Network card number and keep "-"). Run the keygen.bat
   and replace your existing ptc license.dat. You will need to rerun
   setup.bat in the proe_loadpoint\bin and edit and select our
   license file at the start command window.
发表于 2005-11-18 14:01:26 | 只看该作者
emx 是做什么用的
发表于 2005-11-18 21:47:02 | 只看该作者
多谢这位热心人,可我对2.0不熟啊
发表于 2005-11-19 17:21:25 | 只看该作者
原帖由 taoxianshen 于 2005-11-18 13:35 发表
Note: EMX is compatible with Pro/e 2001  ...
暈,怎么是英文,有那位能幫忙翻譯一下
发表于 2005-11-21 15:28:00 | 只看该作者
老兄,可这些英文都是一些简单的呀,都是一些告诉你设定路径的英文.
只要各位照上面的设定去设的话,就可以用了.
发表于 2005-11-21 17:48:19 | 只看该作者
我连EMX 的安装文件都没找着捏.等下去找找先.
发表于 2005-11-21 19:36:53 | 只看该作者
我手上有EMX4.0的,你要吗?
要的话我给你。
GMT+8, 2025-4-25 01:40 , Processed in 0.149375 second(s), 11 queries , Gzip On, Redis On.
