查看: 16692|回复: 2
請教﹕chordal tolerance弦弧誤差是什么意思?
发表于 2003-1-15 14:54:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
生成"點"中有這樣一個 選項﹐但我不明白是什么意思﹗請賜教﹗
TKS
发表于 2003-1-15 19:52:02 | 只看该作者
A chord is the straight line between adjacent coordinates;The
tolerances provide independent values for controlling the output of
the coordinates located on the curve. The chordal tolerance is
the maximum allowable distance from a chord to the curve between
the ends of the chord.
发表于 2003-1-17 09:44:12 | 只看该作者
thanks
GMT+8, 2025-2-27 01:58 , Processed in 0.025143 second(s), 11 queries , Gzip On, Redis On.
