查看: 15896|回复: 1
how to add element to a layer or remove the elements from a
发表于 2003-1-15 15:02:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
how to add element to a layer or remove the elements from a layer?
发表于 2003-1-15 15:24:17 | 只看该作者
1。Define a new layer with Graphic properties toolbar
2. select a element (either in specification tree or in graphic area)
3. select the newly defined  layer。 then the elements is in that layer
select a element, then selec None in Graphic properties toolbar layer drop down menu. then the element is removed from it's original layer
GMT+8, 2025-9-19 18:28 , Processed in 0.061305 second(s), 11 queries , Gzip On, Redis On.
