查看: 16283|回复: 0
求助------有关Measure body...命令的详细说明
发表于 2005-12-1 21:51:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Measurement Mass Properties
Displayed Mass Property Values
Volume                          = 1000000.000000001 mm^3
Area                            = 60000.000000000 mm^2
Mass                            = 7.830634956 kg
Weight                          = 76.792365570 N
Radius of Gyration              = 50.000000000 mm
Centroid                        = 50.000000000, 50.000000000, 50.000000000 mm
Detailed Mass Properties
Analysis calculated using accuracy of 0.990000000
Information Units     Grams - Millimeters
Density               = 0.007830640
Volume                = 1000000.000000000
Mass                  = 7830.640000000
First Moments
Mxc, Myc, Mzc         = 391532.000000000, 391532.000000000, 391532.000000000
Center of Mass
Xcbar, Ycbar, Zcbar   = 50.000000000, 50.000000000, 50.000000000
Moments of Inertia (Work)
Ixxw, Iyyw, Izzw      = 52204266.666666687, 52204266.666666687, 52204266.666666687
Moments of Inertia (Centroidal)
Ixx, Iyy, Izz         = 13051066.666666673, 13051066.666666672, 13051066.666666675
Moments of Inertia (Spherical)
I        = 19576600.000000007
Products of Inertia (Work)
Pyzw, Pxzw, Pxyw      = 19576600.000000007, 19576600.000000007, 19576600.000000007
Products of Inertia (Centroidal)
Pyz, Pxz, Pxy         = 0.000000000, 0.000000000, 0.000000000
Radii of Gyration (Work)
Rxgw, Rygw, Rzgw      = 81.649658093, 81.649658093, 81.649658093
Radii of Gyration (Centroidal)
Rxg, Ryg, Rzg         = 40.824829046, 40.824829046, 40.824829046
Radii of Gyration (Spherical)
R                     = 50.000000000
Principal Axes
Xp(X), Xp(Y), Xp(Z)   = 1.000000000, 0.000000000, 0.000000000
Yp(X), Yp(Y), Yp(Z)   = 0.000000000, 1.000000000, 0.000000000
Zp(X), Zp(Y), Zp(Z)   = 0.000000000, 0.000000000, 1.000000000
Principal Moments
Ixxp, Iyyp, Izzp      = 13051066.666666673, 13051066.666666672, 13051066.666666675
Error Estimates
Volume                          = 0.000000000
Area                            = 0.000000000
Mass                            = 0.000000000
Moments of Inertia (Spherical)  = 0.000000000
Center of Mass                  = 0.000000000, 0.000000000, 0.000000000
Moments of Inertia (Work)       = 0.000000000, 0.000000000, 0.000000000
Products of Inertia (Work)      = 0.000000000, 0.000000000, 0.000000000Sample Text
GMT+8, 2025-4-20 05:41 , Processed in 0.021005 second(s), 12 queries , Gzip On, Redis On.
