查看: 17264|回复: 3
【求助】请教各位大虾,我的UGCAST为何运行不了?
发表于 2002-3-18 11:52:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我刚学UG ,请问UGCAST运行之后 怎么用??
我运行UGCAT出现:
发表于 2002-3-18 19:03:33 | 只看该作者
直接运行cast目录下html下的start.htm就行了吧,改来改去的挺麻烦的,其实都一样
发表于 2002-4-3 17:47:52 | 只看该作者
Because the  cast default is netscape.  You shound install netscape.
发表于 2002-4-3 19:00:46 | 只看该作者
如果用的是IE的话
编辑UGS180\UGCAST\CASTONLY.BAT 文件
对照修改成以下设置:
set UGII_CAST_BROWSER=IE2
rem *******************************************************************
rem * Check the value of UGII_CAST_HTML_URL
if "%UGII_CAST_HTML_URL%" == "" goto noSource
rem * if the value of UGII_CAST_BROWSER is the full path to a
rem * browser then use that browser.
if exist "%UGII_CAST_BROWSER%" goto startBrowser
rem * if the UGII_CAST_BROWSER variable is set to one of the following
rem * short names then use the default location for that browser.
rem * netscape4 = Netscape 4 (Communicator)
rem * IE1, IE2  =  Internet Explorer
rem *
rem * Default locations for the supported Browsers.
set NETSCAPE4_LOC=%SYSTEMDRIVE%\Program Files\Netscape\Communicator\Program\netscape.exe
set IE1_LOC=%SYSTEMDRIVE%\Program Files\Microsoft Internet\Iexplore.exe
set IE2_LOC=%SYSTEMDRIVE%\Program Files\Internet Explorer\Iexplore.exe
if "%UGII_CAST_BROWSER%" == "netscape4" set UGII_CAST_BROWSER=%NETSCAPE4_LOC%
if "%UGII_CAST_BROWSER%" == "IE1" set UGII_CAST_BROWSER=%IE1_LOC%
if "%UGII_CAST_BROWSER%" == "IE2" set UGII_CAST_BROWSER=%IE2_LOC%
GMT+8, 2025-4-28 22:26 , Processed in 0.021442 second(s), 15 queries , Gzip On, Redis On.
