查看: 15542|回复: 0
紧急求助!@
发表于 2005-12-9 20:35:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
关于80个节点的网络版的安装啊,,我经常单机的安装,可网络的不会啊!!!
老大们,,帮我!!!
如下内容!
          on  the license server/ fole server
         1.compleled steps  (1-11) of pro/engineer,installed ,locally,on each client machine from above
        on the license client /file clicent machine
         2.map a network drive from the client to a location on the file server which will give the client access to the
            pro/engineer software
         3. set the path environment variable to the <loadpoint> \bin directory
正版的和盗版的一样的,,只是价格贵!!!
1到111就是一般的单机安装!
GMT+8, 2025-2-9 03:00 , Processed in 0.021881 second(s), 9 queries , Gzip On, Redis On.
