查看: 16374|回复: 0
CosMosMotion模拟出现问题!!谢谢!!
发表于 2005-12-11 11:19:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我是新手,希望大家多多指点。
--- Simulating 摇摆环装配体2 on 2005年12月08日 19:40:47, Frames: 200, Time: 1 ---
At time  0.430000000E-02 the integrator is unable to proceed.  Possible Causes:
(1) The accuracy required for the numerical solution can not be attained.
Relax (increase) the value of the acceptable integration ERROR.
(2) Incompatible redundant constraints, a lock up, or a bifurcation
situation.  The latter two indicate a mechanism design problem.
(3) The system includes a zero (or relatively small) mass on a part with
an unconstrained translational degree of freedom.
Make sure you have mass on all parts with translational degrees of freedom.
(4) The system includes a zero (or relatively small) inertia on a part
with an unconstrained rotational degree of freedom.
Make sure you have inertias on all parts with rotational degrees of freedom.
(5) An ADAMS element has a function expression that equals exactly itself.
For example,
     SFORCE/id1,I=id2,J=id3,ROT,FUNC=SFORCE(id1,jflag,comp,rm),and
     DIFF/id4,IMPLICIT,IC=0,FUNC=DIF1(id4).
Similarly,
     VARIABLE/id5, FUNC=VARVAL(id5)*TIME
equals itself at 1 second. Avoid setting an ADAMS element equal to itself.
--- Simulation ended on 2005年12月08日 19:40:47 ---
--- Simulating 摇摆环装配体2 on 2005年12月08日 19:41:05, Frames: 200, Time: 1 ---
For example,
Similarly,
--- Simulation ended on 2005年12月08日 19:41:06 ---
GMT+8, 2025-7-8 15:18 , Processed in 0.019659 second(s), 11 queries , Gzip On, Redis On.
