查看: 16044|回复: 0
求救单元法向不一致的解决办法!
发表于 2005-12-13 14:46:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
"The normal of target element 36671 is not consistent with the normal of target element 37579.
Using ENORM command to correct it."请问,这个提示是什么意思啊?如何解决呢?
GMT+8, 2025-4-28 05:09 , Processed in 0.040936 second(s), 11 queries , Gzip On, Redis On.
