查看: 16473|回复: 4
求助:Catia V5R14中Dump of Parameters 有什么作用?
发表于 2005-12-20 15:23:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
CATIA V5R14中Option--Dump of Parameters 有什么作用?
发表于 2005-12-20 22:15:29 | 只看该作者
The Tools->Options... dialog box contains a button
for dumping settings to a .vbs script macro file:
Click the dump button to open the following dialog
box, then specify which settings to dump, the
output directory for the dump, then click Yes.
The resulting macro recovers settings values: the
values are represented as comments in the macro.
This function is only implemented on a limited
number of tabs. The objects involved are derived
from SettingController. For documentation on the
corresponding Automation interfaces, refer to the
Automation Home page in the CAA V5 Encyclopedia.
发表于 2005-12-21 09:52:48 | 只看该作者
谢谢楼上
不过我还是不太明白,
我们日常工作有什么作用吗?
发表于 2005-12-21 17:58:19 | 只看该作者
参数的编程序设置。
发表于 2005-12-21 19:16:14 | 只看该作者
谢谢,简单明了
GMT+8, 2025-2-24 20:04 , Processed in 0.031227 second(s), 10 queries , Gzip On, Redis On.
