查看: 18238|回复: 10
【原创】画圆中心线的程序
发表于 2003-1-22 12:59:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
不知道谁有能画圆中心线的lsp,请贴一个上来看看,谢谢了!
发表于 2003-1-22 13:51:37 | 只看该作者
;程序名:画中心线程序
;程序者:向志奇
;建立时间:1998-04-16
;最后修改时间:1999-03-5
;附带文件:
(defun c:zxx(/ la lt cl p1 e ed sel sel1 cen rad pt1 pt2 pt3 pt4 aper os)
(setq la (getvar "clayer"))
(setq lt (getvar "celtype"))
(setq cl (getvar "cecolor"))
(setq aper (getvar "aperture")    )
(setq os (getvar "osmode") )
(setq temperr *error*)
(setq *error* trap)
(command "undo" "be")
(princ "\n画中心线程序")
(setq p1 (entsel "\n请选取圆或圆弧:"))
(if (not p1)
    (progn
      (princ "\n没有选到实体!")
      (exit)
(setq ed (entget (setq e (nth 0 p1))))
(setq sel (cdr (assoc 0 ed)))
(while
(or (= sel "CIRCLE") (= sel "ARC"))
(setq cen (cdr (assoc 10 ed)))
(setq rad (cdr (assoc 40 ed)))
(setq pt1 (list (- (nth 0 cen) (+ rad 1)) (nth 1 cen)))
(setq pt2 (list (+ (nth 0 cen) (+ rad 1)) (nth 1 cen)))
(setq pt3 (list (nth 0 cen) (- (nth 1 cen) (+ rad 1))))
(setq pt4 (list (nth 0 cen) (+ (nth 1 cen) (+ rad 1))))
(setvar "clayer" "YHCENTER")
(setvar "celtype" "BYLAYER")
(setvar "cecolor" "BYLAYER")
(setvar "aperture" 1)
(setvar "osmode" 0 )
(command "line" pt1 pt2 "")
(command "line" pt3 pt4 "")
(setvar "osmode" os )
(setvar "aperture" aper)
(setvar "clayer" la)
(setvar "celtype" lt)
(setvar "cecolor" cl)
(setq sel1 sel)
(setq sel nil)
(if (not (or (= sel1 "CIRCLE") (= sel1 "ARC")))
(princ"\n选取的不是圆或圆弧!"))
(command "undo" "e")
(princ)
发表于 2003-1-22 13:53:02 | 只看该作者
这笑脸烦人。再贴一个
发表于 2003-1-22 17:59:42 | 只看该作者
a7web wrote:
这笑脸烦人。再贴一个
谢谢!
发表于 2003-1-23 21:56:25 | 只看该作者
好東東!
发表于 2003-2-19 19:44:15 | 只看该作者
可以同時處理同心圓..我台自台灣..從是模具設計and 模具二次軟件開發
請多指教
;;CENTER.LSP
;;draw clrcle or arc #CENMARK line
(DEFUN C:CENO() (SETQ KW@ "O") (#CENMARK)) ;;;繪中心線
(DEFUN C:CENI() (SETQ KW@ "I") (#CENMARK)) ;;;繪中心mark
(defun cEN_err(st)
   (setvar "osmode" osmode)
   (setvar "clayer" clay)
   (setq *error* old_err)
   (princ)
(DEFUN #CENMARK(/ cy sa eetn aa cc1 cc4  ch
       cucs sl en ena enb cp1 cp2 cp3 cp4 r rr)
(setq cy (getvar "clayer"))
(setq old_err *error* *error* cEn_err)
(setq osmode (getvar "osmode"))
(setvar "osmode" 0)
(if (null eet) (setq eet (abs (* (getvar "dimscale") (getvar "dimcen")))))
(INITGET ".")
(setq eet (ureal  0 "" "Extension length" eet))
(setvar "CMDECHO" 0)
(setq sa (ssget))
(setq n (sslength sa))
(setq i 0)
(setq da@ '())
(while (< i n)
    (setq ch nil)
    (setq eetn (ssname sa i))
    (setq aa (dxfa 0 eetn))
    (IF (OR (= "CIRCLE" AA) (= "ARC" AA))
       (progn
   (setq cc1 (dxfa 10 eetn))
   (setq cc4 (dxfa 40 eetn))
   (setq dda (list cc1 cc4))
   (setq sl (length da@))
   (setq w 0)
   (WHILE (and (/= ch "E") (<= w sl))
       (if (/= da@ nil)
        (progn
        (setq en (nth w da@))
        (setq ena (car en))
        (setq enb (cadr en))
          (cond((equal ena cc1 0.005)
            (IF (= KW@ "I")
          (if (> enb cc4)
              (setq da@ (subst dda en da@))
          (if (< enb cc4)
            (setq ch "E")
          (T
            (if (or (and (= w sl) (not (equal ena cc1))) (= sl 0))
            (progn
              (setq da@ (cons dda da@))
              (setq ch "E")
          );cond
        (setq w (1+ w))
     (setq i (1+ i))
  ) ;while
;;----------------draw #CENMARK line-------------
  (setq !sl (length da@))
  (setq i 0)
  (COMMAND "LAYER" "S" "CENTER" "")
  (repeat !sl
      (setq ent (nth i da@))
      (setq cen (trans (car ent) 0 1))
      (setq r (cadr ent))
      (IF (= KW@ "I")
          (PROGN
          (if (null eet)
        (setq rr (* 0.3 r))
        (setq rr eet)
          (setq cp1 (list (car cen) (+ (cadr cen) rr)))
          (setq cp2 (list (car cen) (- (cadr cen) rr)))
          (setq cp3 (list (- (car cen) rr) (cadr cen)))
          (setq cp4 (list (+ (car cen) rr) (cadr cen)))
          (PROGN
          (if (null eet)
        (setq rr (* 0.1 r))
        (setq rr eet)
          (setq cp1 (list (car cen) (+ (cadr cen) r rr)))
          (setq cp2 (list (car cen) (- (cadr cen) r rr)))
          (setq cp3 (list (- (car cen) r rr) (cadr cen)))
          (setq cp4 (list (+ (car cen) r rr) (cadr cen)))
      (command "line" cp1 cp2 "")
      (command "line" cp3 cp4 "")
      (setq i (1+ i))
  (command "setvar" "highlight" "1")
  (command "layer" "set" cy "")
  (setvar "cmdecho" 1)
  (PRINC)
;;----副程式----------------------------------------------------------
(defun ureal (bit kwd msg def / msg bit inp)
    (if def
      (setq msg (strcat "\n" msg " <" (rtos def 2) ">: ")
      bit (* 2 (fix (/ bit 2)))
      (setq msg (strcat "\n" msg ": "))
      (initget bit kwd)
      (setq inp (getreal msg))
      (if inp inp def)
(defun dxfa (code entity)
   (cdr (assoc code (entget entity)))
发表于 2003-2-19 20:33:37 | 只看该作者
a7web wrote:
这笑脸烦人。再贴一个
下载后,这个东东咋用????
发表于 2003-2-19 20:55:31 | 只看该作者
这笑脸烦人。再贴一个
发表于 2003-2-19 20:56:14 | 只看该作者
模头 wrote:
  下载后,这个东东咋用????
下載后的文件(文件名為ZXX.lsp)放在CAD的support目錄下。
在命令行輸入:(load"zxx") 回車!
再輸入:zxx 回車!
再試試!::y
发表于 2003-2-19 21:07:25 | 只看该作者
Jacky Wang wrote:
  下載后放在CAD的support目錄下。
  在命令行輸入:(load"zxx")
  再輸入:zxx 回車!
  試試!::y
大哥,能不能贴张图演示一下,我试过了好象不行。::?::?
GMT+8, 2025-2-24 03:38 , Processed in 0.025919 second(s), 11 queries , Gzip On, Redis On.
