查看: 15434|回复: 0
[问]作sweep feature时遇到的不懂之处
发表于 2006-1-9 21:51:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我画了一条不封闭的曲线作为trajectory,但是勾选完成时pro-e显示提示信息如下:
Select a perpendicular surface, an edge, or vertex relative to which the section will be dimensined and constrained.
曲线在Front面,在该面内已constrain. 当我按照提示点选Top面作为perpendicular surface时,系统又提示:
Section must contain geometric entities for this feature.
勾选失败.
请问我应如果操作.
GMT+8, 2025-4-29 01:26 , Processed in 0.021431 second(s), 11 queries , Gzip On, Redis On.
