查看: 16124|回复: 7
【求助】我的i-deas把网断了怎么不能用了?救救我呀
发表于 2003-1-25 00:25:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天把机器拿家重装了,以前的网卡没有拆,又加了个虚拟网卡,用虚拟网卡注册的,怎么说我找不到flexlm lock server 让我review licience
erro -97
erro  -92
这是怎么回事呀,还请各位大侠指点,我是初学,在这里多谢了
发表于 2003-1-25 01:21:20 | 只看该作者
老兄上两张网卡吧
记住IP要不同哟
我试验过没问题
发表于 2003-1-25 08:35:01 | 只看该作者
问题肯定没有,但是I-DEAS安装时的网卡好像是不可以由自己选的,也就是说,它在安装过程中会告诉你一个HostID,也就是网卡的MAC地址,如果你有两个网卡的话,他认哪一个不是让你选的,大概是他认准了以前那个网卡吧。
发表于 2003-1-25 10:37:21 | 只看该作者
忘了告诉两张网卡要用网线联起来哟!!!!!!!!!
试验一下吧!:P:P:P
发表于 2003-1-27 09:19:12 | 只看该作者
翻看一下前面的贴吧,注册表里改一下就好了。
发表于 2003-1-27 13:27:37 | 只看该作者
还没回去亚?还以为你回家了那,昨天导弹来找来着,有几个CAE问题,
问我,我也不懂:~)
发表于 2003-1-27 13:36:27 | 只看该作者
30号。导弹的热我也不懂啊
发表于 2003-1-27 16:33:00 | 只看该作者
The registry parameter is "DisableDHCPMediaSense".
See I-deas tech tip 151 at https://uganswer.plms-eds.com/
The direct Microsoft knowledge base link (article Q239924) is:
https://support.microsoft.com/support/kb/articles/Q239/9/24.asp
Jim
Karsten Glass wrote:
> Hello Iccon !
> Someone I would like to help, needs to run ideas on a notebook
> (stand-alone) for presentation purposes.
> The appropriate notbook is equiped with Win2k.
> I have implemented a local license for running I-deas.
> You know, when that if there is no network wire plugged in to the
NIC,
> the necessary networkservices
> for running the licensedaemon are not available.
> -> I believe that there is a registry entry, which is controlling
this
> (mis-) behaviour.
> Does anyone knows which  / where to find it (Or any other useful hint
> regarding to this)?
> Thanks a lot for any help !
> Have a nice day, Regards
> Karsten Glass; APCAD Bremen
GMT+8, 2025-4-9 07:12 , Processed in 0.051699 second(s), 11 queries , Gzip On, Redis On.
