查看: 15902|回复: 3
How to setup hp Designjet 450C?
发表于 2003-1-26 23:05:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hi all,
Anyone know how to setup plotter in Unigraphics v18 and NX under WinXP?
Thanks in advance!!
发表于 2003-1-26 23:59:10 | 只看该作者
搜搜以前的帖子,今天我已经按其指导安装成功了HP250C喷墨出图机和惠普4LC激光打印机。
发表于 2003-1-29 13:59:49 | 只看该作者
plot 的设置要在——程序——Unigrhpics Tools——PQMGR窗口下用qadd命令增加一个绘图程序。具体内容可以参考有关资料(用qmod xxx命令看现有的程序设置,xxx 是已经存在的一个绘图程序,例如:
Despooler Name          = UGIIHP
Plotter Vendor          = HEWLETT-PACKARD
Plotter Type            = Electrostatic
Number Of Pens          = 8
Controller ID           =
Plotter Model           = 7600
Plotter Switches        = /2/AR/SP=MW
Media Control           = Continuous Form
Distance Between Plots  = 0
Output Mode             = Queue
Plotter Com Line        =
System Queue Name       = LPT1
Directory Pathname      =
Tape Density            = 1600
Message Interval        =
Message Com Line        =
Horizontal Maximum      = 0
Vertical Maximum        = 0
Steps Per Inch          = 1016
Optimization Level      = None
发表于 2003-2-25 20:17:09 | 只看该作者
找到C:\WINNT\system32\spool\ugplot\plot.queues文件,用记事本打开
修改如下
PLRID=DJ650C        --》可以改为DJ450C
INTEGRITY_ID=0006
DSPNM=UGIIHP
PLTVEN=HEWLETT-PACKARD
TYPE=E
MODEL=7600
SWITCHES=/2/SP=CN/D=300/AR
OUTMOD=2
COMLN=
QUENAM=\\MYNODE\DJET_COLOR  --》\\装DJ450C的计算机名
                                                               \DJ450C的共享名
OUTDIR=
NPENS=16
DXBET=0
STPSZ=1016
重启OK!
GMT+8, 2025-2-27 10:09 , Processed in 0.022785 second(s), 11 queries , Gzip On, Redis On.
