查看: 17157|回复: 1
十字光标角度调整
发表于 2006-1-20 22:55:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
;;;********************************************************************1
;十字光标角度调整 Command:AC
;;;Version 1.0
(defun c:AC (/ en ang entyp pt10 pt11)
  (setq en (entsel "\n选取线、文字或图块 <0>: "))
  (if en
    (progn
      (setq endata (entget (car en)))
      (setq entyp (cdr (assoc 0 endata)))
      (cond ((= entyp "LINE") (line-ang))
            ((= entyp "TEXT") (text-ang))
            ((= entyp "INSERT") (text-ang))
            (t (2p-ang))
    (setq ang 0)
  (setvar "snapang" ang)
  (princ
    "\n---Bye c:Ac 光标角度调整!---"
  (prin1)
(defun line-ang        ()
  (setq pt10 (cdr (assoc 10 endata)))
  (setq pt11 (cdr (assoc 11 endata)))
  (setq ang (angle pt10 pt11))
(defun text-ang        ()
  (setq ang (cdr (assoc 50 endata)))
(defun 2p-ang ()
  (setq ang (getangle "\n输入角度值: "))
发表于 2006-5-2 13:57:22 | 只看该作者
兄弟,我感觉你是简单问题复杂化,
直接在ACAD.PGP中加入  "AC,      *snapang"
不过,我不会编程,还是很欣赏你的编程能力
GMT+8, 2025-4-25 23:16 , Processed in 0.023884 second(s), 12 queries , Gzip On, Redis On.
