查看: 18927|回复: 6
sinderal 版主帮看看我的配置
发表于 2006-1-22 13:54:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用来打开SW文件,结果打不开,我的SFCAM安装路径D:\Program Files\SURFCAM\SURFCAM\Velocity
在INI文件里配置如下
[FileOpenSave]
DEM=DEMO Files(*.SCEDU;*.DEM), "*.SCEDU;*.dem;*.SCPRT*;*.dsn;*.tle;*.tlm;*.tmp",,,scprtread,,,APPEND_FALSE
SCEDU=SCEDU Files(*.SCEDU), "*.SCEDU",,,,scprtwrite,,APPEND_FALSE
;SCPRTDSN=SCPRT and DSN Files(*.SCPRT;*.DSN), "*.SCPRT*;*.SCEDU;*.SCBAK;*.dsn;*.tle;*.tlm;*.tmp",,,scprtread,,,APPEND_NEVER
SCPRT=SURFCAM Files(*.scprt), "*.SCPRT;*.SCEDU;*.SCBAK",,,scprtread,scprtwrite,,APPEND_NEVER
SCPRT2005=SURFCAM v2005 Files(*.SCPRT), "*.SCPRT",,,,scprtwrite2v2005,,APPEND_FALSE
DSN=DSN(*.dsn), "*.dsn;*.tle;*.tlm;*.tmp",,,scprtread,,,APPEND_NEVER
;OLDSW=SOLIDWORKS Part(*.prt;*.sldprt), "*.prt;*.sldprt",D:\Program
Files\SURFCAM\SURFCAM\Velocity\Trans\PrsdDll\prsd2scprt.dll,,Sldwrk2DsnEntryPoint,,,APPEND_FALSE
SW=SolidWorks Files(*.prt;*.sldprt), "*.prt;*.sldprt",OpenSwPart.dll,,Sldwrk2DsnEntryPoint,,,APPEND_FALSE
SWA=SolidWorks Assembly(*.sldasm), "*.sldasm",OpenSwAssembly.dll,,ReadSwAssembly,,, APPEND_FALSE
DWG=DXF DWG(*.dxf;*.dwg), "*.dwg;*.dxf",[REPLACE]\Velocity\Trans\DWGDirect\OdReadExDLL.dll,,AutoCADReadEntry,,,APPEND_FALSE
DXFS=DXF(*.dxf), "*.dxf",,[REPLACE]\Velocity\Trans\scprt2dwg.dll,,DxfEntryPoint,,APPEND_FALSE
DWGS=DWG(*.dwg), "*.dwg",,[REPLACE]\Velocity\Trans\scprt2dwg.dll,,fpsDllEntryPoint,,APPEND_FALSE
IGS=IGES(*.igs;*.iges), "*.igs;*.iges",D:\Program Files\SURFCAM\SURFCAM\Velocity\Trans\igs2scprt.dll,D:\Program
Files\SURFCAM\SURFCAM\Velocity\Trans\scprt2igs.dll,SurfcamDllEntryPoint,SurfcamDllEntryPoint,,APPEND_FALSE
SAT=ACIS(*.sat),
"*.sat",[REPLACE]\Velocity\Trans\SpatialDll\sat2scprt.dll,[REPLACE]\Velocity\Trans\SpatialDll\scprt2sat.dll,Sat2DsnEntryPoint
,Dsn2SatEntryPoint,,APPEND_FALSE
PRSD=Parasolid(*.x_t;*.x_b),
"*.x_t;*.x_b",[REPLACE]\Velocity\Trans\Prsddll\prsd2scprt.dll,[REPLACE]\Velocity\Trans\Prsddll\prsd2scprt.dll,Prsd2DsnEntryPo
int,Dsn2XtEntryPoint,,APPEND_FALSE
NewPar=Solid Edge(*.par), "*.par",[REPLACE]\Velocity\Trans\Prsddll\prsd2scprt.dll,,NewSe2DsnEntryPoint,,,APPEND_FALSE
VDA=VDA-FS(*.vda),
"*.vda",[REPLACE]\Velocity\Trans\vda2scprt.dll,[REPLACE]\Velocity\Trans\scprt2vda.dll,SurfcamDllEntryPoint,SurfcamDllEntryPoi
nt,,APPEND_FALSE
CADL=CADL(*.cdl),
"*.cdl",[REPLACE]\Velocity\Trans\cadl2scprt.dll,[REPLACE]\Velocity\Trans\scprt2cadl.dll,SurfcamDllEntryPoint,SurfcamDllEntryP
oint,,APPEND_FALSE
STL=STL(*.stl), "*.stl",,[REPLACE]\Velocity\Trans\scprt2stl.dll,,SurfcamDllEntryPoint,,APPEND_FALSE
NCC=G-Code(*.ncc), "*.ncc",[REPLACE]\Velocity\Trans\dig_dll.dll,,SurfcamDigtNccEntryPoint,,,APPEND_FALSE
CM=Cam Profile(*.cm), "*.cm",[REPLACE]\Velocity\Trans\caminc.dll,,SurfcamCamDllEntryPoint,,[REPLACE]\scprt,APPEND_FALSE
GR=Gear Profile(*.gr), "*.gr",[REPLACE]\Velocity\Trans\gearinc.dll,,SurfcamGearDllEntryPoint,,[REPLACE]\scprt,APPEND_FALSE
INV=Involute Curve (*.inv),
"*.inv",[REPLACE]\Velocity\Trans\gearinc.dll,,SurfcamInvoluteDllEntryPoint,,[REPLACE]\scprt,APPEND_FALSE
ASC=ASCII Data(*.asc), "*.asc",[REPLACE]\Velocity\Trans\dig_dll.dll,,SurfcamDigtAsciiEntryPoint,,,APPEND_FALSE
CATIV=*CATIA 4(*.model
*.exp),"*.model;*.exp",[REPLACE]\Velocity\Trans\SpatialDll\cativ2scprt.dll,,ScCativ2DsnEntryPoint,,,APPEND_FALSE
CATV=*CATIA 5(*.catpart),"*.catpart",[REPLACE]\Velocity\Trans\SpatialDll\catv2scprt.dll,,Catv2DsnEntryPoint,,,APPEND_FALSE
PROENEW=*ProE(*.prt;*.prt.*), "*.prt;*.prt.*", [REPLACE]\Velocity\Trans\SpatialDll\scproe2scprt.dll,,
ScProe2DsnEntryPoint,,,APPEND_FALSE
STEP=*STEP
AP203/214(*.step;*.stp),"*.step;*.stp",[REPLACE]\Velocity\Trans\SpatialDll\step2scprt.dll,,Step2DsnEntryPoint,,,APPEND_FALSE
UGF=*UGII(*.prt), "*.prt",[REPLACE]\Velocity\Trans\SpatialDll\ugf2scprt.dll,,Ug2DsnEntryPoint,,,APPEND_FALSE
INVT=*Inventor(*.ipt), "*.ipt",[REPLACE]\Velocity\Trans\SpatialDll\invt2scprt.dll,,Invt2DsnEntryPoint,,,APPEND_FALSE
结果IGES文件可以打开,但SW文件打不开,提示如下
帮我看看,配置文件那里出错了.
发表于 2006-1-24 10:16:13 | 只看该作者
為什麼有一堆[REPLACE]? D:\SURFCAM\SURFCAM\VELOCITY\? 兩個surfcam.....
移除, 重裝在D:\surfcam\
发表于 2006-1-27 18:16:11 | 只看该作者
呵呵,,多谢啊,,已按你的话解决了,,到年了,也祝你新年快乐,更进一步.
发表于 2006-2-18 21:08:39 | 只看该作者
大老头好像冬眠了耶^_^
发表于 2006-2-22 17:05:11 | 只看该作者
原帖由 laopu_sd 于 2006-2-18 21:08 发表
大老头好像冬眠了耶^_^
又没多少人提问! 而且赶 客户的工件, 4+1, 3+2....不锈钢 难切地要命
头像被屏蔽
发表于 2006-2-22 19:18:05 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2006-2-27 14:49:52 | 只看该作者
原帖由 sinderal 于 2006-2-22 17:05 发表
4+1是什么意思?
请说明,最好举个例子!
GMT+8, 2025-2-2 14:43 , Processed in 0.032411 second(s), 10 queries , Gzip On, Redis On.
