查看: 16357|回复: 0
求助: dynaform模拟时出现错误,不知道产生的原因和怎么修改,哪位能帮帮忙啊
发表于 2006-2-7 20:12:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
******** termination due to mass increase *******
          added mass       =     3.8904E-05
          percent increase =     5.2325E+04
            nodes with largest mass increase
   node id      old mass        new mass        increase
      6664     2.77922E-12     7.22377E-08     7.22349E-08
      7270     2.77327E-12     7.16124E-08     7.16096E-08
      6447     2.11195E-12     7.10635E-08     7.10614E-08
      6491     2.20378E-12     6.82083E-08     6.82061E-08
      6492     2.21123E-12     6.74153E-08     6.74131E-08
      7217     2.21174E-12     6.73829E-08     6.73807E-08
      7143     2.20338E-12     6.72287E-08     6.72265E-08
      7169     2.18565E-12     6.69398E-08     6.69376E-08
      7218     2.20055E-12     6.68937E-08     6.68915E-08
      6448     2.18708E-12     6.66745E-08     6.66723E-08
      6601     2.45765E-12     6.51692E-08     6.51668E-08
      7272     1.78190E-12     6.19338E-08     6.19320E-08
      6602     1.77101E-12     6.00969E-08     6.00951E-08
      6572     1.74897E-12     5.85651E-08     5.85633E-08
      6446     2.18857E-12     5.67614E-08     5.67592E-08
      6428     1.75049E-12     5.66360E-08     5.66342E-08
      6426     2.40544E-12     5.58787E-08     5.58763E-08
      6695     1.85627E-12     5.57794E-08     5.57776E-08
      6632     1.76092E-12     5.57317E-08     5.57300E-08
      6694     2.39867E-12     5.53555E-08     5.53531E-08
   total added mass for these 20 nodes =  1.26752E-06
       1 t 8.4159E-07 dt 8.42E-07 write d3dump01 file
       1 t 8.4159E-07 dt 8.42E-07 write d3plot file
E r r o r   t e r m i n a t i o n
   Memory required for explicit solution:      1210318
Additional dynamically allocated memory:            0
                                   Total:      1210318
T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Initialization ....... 4.0000E+00   80.00     4.5940E+00   84.73
  Element processing ... 0.0000E+00    0.00     2.6500E-01    4.89
  Binary databases ..... 0.0000E+00    0.00     3.2800E-01    6.05
  ASCII database ....... 0.0000E+00    0.00     1.2500E-01    2.31
  Contact algorithm .... 1.0000E+00   20.00     7.9000E-02    1.46
  Contact entities ..... 0.0000E+00    0.00     0.0000E+00    0.00
  Rigid bodies ......... 0.0000E+00    0.00     3.1000E-02    0.57
  Implicit Nonlinear ... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Lin. Alg. ... 0.0000E+00    0.00     0.0000E+00    0.00
  T o t a l s            5.0000E+00  100.00     5.4220E+00  100.00
Problem time       =    8.4159E-07
Problem cycle      =         1
Total CPU time     =         5 seconds (   0 hours  0 minutes  5 seconds)
CPU time per zone cycle  =    184877 nanoseconds
Clock time per zone cycle=    153078 nanoseconds
Number of CPU's     1
Start time   02/07/2006 20:04:32
End time     02/07/2006 20:04:57
Elapsed time       25 seconds (   0 hours  0 minutes 25 seconds)
[ 本帖最后由 madly 于 2006-2-8 19:15 编辑 ]
GMT+8, 2025-4-19 22:45 , Processed in 0.051927 second(s), 10 queries , Gzip On, Redis On.
