CAA问题
发表于 2006-2-14 11:42:50 | 只看该作者
CATApplication.Subscribe用法如下:
o Subscribe
public int Subscribe( int                     iSubscribingType,
                               CATCommand*  iToClient,
                               void*                  iClientData,
                              void(*)()              UserStaticMethod)
                Adds a transaction/idle subscription to a command.
Parameters:
iSubscribingType
               The subscribing type.
                Legal values: Can be set to CATSubscribeEndTransaction (=1) or to CATSubscribeIdle (=2)
iToClient
               The command to call with its UserStaticMethod
iClientData
               Data useful to UserStaticMethod
UserStaticMethod
              The method to call when the state defined by iSubscribingType is reached.
Returns:
              0 if the transaction/idle subscription is successfully added and 0 otherwise
我主要不知道那几个参数都写什么,返回值是哪个啊?
[ 本帖最后由 xinghesnak 于 2006-2-14 11:48 编辑 ]
发表于 2006-2-15 08:40:43 | 只看该作者
小弟发现不光selection.selectelement2报错,selectelement和selectelement3也同样报错,好像是只要是在VBA中交互式操作,用CAA调用就会报错......高手们帮忙啊!
发表于 2006-2-15 13:48:09 | 只看该作者
顶顶......^_^
发表于 2006-2-16 08:05:29 | 只看该作者
雄起!雄起!
发表于 2006-2-16 09:25:18 | 只看该作者
帮你顶顶,手头没环境
看看callback
发表于 2006-2-17 15:41:52 | 只看该作者
callback是什么东东?^_^
发表于 2006-2-20 08:03:35 | 只看该作者
还是要顶,真的没有人会吗?
18
发表于 2006-2-21 14:39:00 | 只看该作者
                               void*                  iClientData,
iSubscribingType: 1 or 2, you can try both
iToClient: pointer to your(?) command
iClientData: Do you want to pass some data to your command? if no, set it NULL; yes? pointer to your data.
UserStaticMethod: pointer to a method of your command which must be "static", this will be used as a callback. (so if some event happens, system will call this method, this is called "callback")
However I don't think you REALLY want to use this.
Better paste you VBA code and mark where the error occurs, and the error messsages.
So someone familiar with VBA could help you.
I don't think anybody here ever have chance to use this CATApplication::Subscribe().
19
发表于 2006-2-21 17:01:30 | 只看该作者
To saeba:Thank you very much!
VBA code and mark where the error occurs is:
Function GetPart(InfString As String, Optional Product As Product, Optional RootProduct As Product) As Part
          Dim TagPrduct, Status
          ReDim InputObjectType(0)
          InputObjectType(0) = "Product"
          LocSel.Clear
          Status = LocSel.SelectElement3(InputObjectType, "选择用来存放 " & InfString & " 的 Product:", False, CATMultiSelTriggWhenSelPerf, False)                                               *********错误的就是这行,就是屏幕选取受到限制
end function
how to replace CATApplication::Subscribe() to the first parameter of CATUtilities::executescript()????
where is the return value of CATApplication::Subscribe()??
For example:The path of MyVBA projectis:"d:\1.catvba",two moudle:"11"and "22"--------"Sub main"
20
发表于 2006-2-21 18:55:01 | 只看该作者
what is the error message?
>我看CAA帮助说需要用 CATApplication.Subscribe 来返回第一个参数值
I don't understand why...
Could you paste this part of the document?
>how to replace CATApplication::Subscribe() to the first parameter of >CATUtilities::executescript()????
The first parameter of CATUtilities::executescript() is a UncodeString...
GMT+8, 2025-9-19 00:28 , Processed in 0.049829 second(s), 10 queries , Gzip On, Redis On.
