查看: 23405|回复: 28
CAA问题
发表于 2006-2-9 14:20:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用ExecuteScript运行CATVba程序,可是调试总过不去。。。大哥们帮忙!
#include "TestCmd.h"
#include "CATIndicationAgent.h"
#include "CATMathPlane.h"
#include "CATScriptUtilities.h"
#include "CATCreateExternalObject.h"
#include "CatScriptLibraryType.h"
#include "CATVariant.h"
CATCreateClass(TestCmd);
CATUnicodeString  functionName("CATMain");
CATUnicodeString& iFunctionName=functionName;
CATVariant  var;
TestCmd::TestCmd() :
  CATStateCommand ("TestCmd", CATDlgEngOneShot, CATCommandModeExclusive)
  ,_Indication(NULL)
    CATScriptUtilities::ExecuteScript("C:\\Documents and Settings\\liguangyi\\Local Settings\\Temp\\VBAProject1.catvba", catScriptLibraryTypeVBAProject, "模块1", var, iFunctionName, NULL, 0,TRUE);
报错如下:
## start step: link2nd   at 02/09/2006-14:02:37
# make: ASSET\CmdModule.m intel_a\code\bin\CmdModule.dll
TestCmd.obj : error LNK2001: unresolved external symbol "__declspec(dllimport) public: static long __stdcall CATScriptUtilities::ExecuteScript(class CATUnicodeString const &,enum CatScriptLibraryType,class CATUnicodeString const &,struct tagVARIANT &,class CATUnicodeString const &,struct tagVARIANT *,unsigned int,unsigned char)" (__imp_?ExecuteScript@CATScriptUtilities@@SGJABVCATUnicodeString@@W4CatScriptLibraryType@@0AAUtagVARIANT@@0PAU4@IE@Z)
D:\WORK\CATIA-VC++\workspace2\.\intel_a\code\bin\CmdModule.dll : fatal error LNK1120: 1 unresolved externals
# make-ERROR: intel_a\code\bin\CmdModule.dll
## end   step: link2nd   at 02/09/2006-14:02:38
## start step: dummynls   at 02/09/2006-14:02:38
## end   step: dummynls   at 02/09/2006-14:02:38
== Command done, return code = 0
     小弟觉得参数1和参数3有问题,可是论坛里没有这方面的帖子,相关的也只是引用script程序,不是引用CATVba程序,初学不会,见笑了。望高手们明示.....
发表于 2006-2-9 14:50:41 | 只看该作者
Nothing to do with the parameters. It is only a link error.
You have to insert the right module name in your make file. (mkmake?).
发表于 2006-2-9 17:01:53 | 只看该作者
我的VBA模块名就叫"模块1"啊?没有错误。。。另外seaba兄的英语真好哈^_^
发表于 2006-2-10 11:28:36 | 只看该作者
如果你觉得参数1和参数3有问题
那么就加
CATUnicodeString.h+强制cast
试试看be
发表于 2006-2-10 13:35:33 | 只看该作者
还是不行啊。。。。
发表于 2006-2-10 17:12:26 | 只看该作者
Sorry i don't have Chinese IME installed so I can only type alphabets...
-_-...     I mean there is nothing to do with your source.
You error is a link error, say, the linker can not find the good object to link the symbol "ExecuteScript@CATScriptUtilities...".
So you have to tell the linker where to find it.
To do this, you have to add the module name which contains the symbol "ExecuteScript@CATScriptUtilities..." in your makefile (NOT the cpp file!).
(nothing to do with your VBA模块名!!!)
There is a file in the same directory (named src?) of your cpp files which has a name like ***.mkmake or something.
You have to edit this file.
So what to add? You can place your mouse pointer on the word CATScriptUtilities and press Ctrl+F1 so a help window will appear, and in the bottom of the page, there should be the module name.
Sorry I don't have CAA any longer so can't help you more but you can ask anyone who knows how to edit a makefile.
[ 本帖最后由 saeba 于 2006-2-10 17:14 编辑 ]
发表于 2006-2-10 21:32:30 | 只看该作者
应确保每一个caa头文件所需要的module都包含在imakefile.mk文件中。
发表于 2006-2-11 10:19:00 | 只看该作者
说一句,saeba兄,你没有装输入法?你在国外啊?不过,多谢你的建议,我已经调试成功了。我的参数设置没有问题,就是在Imakefile.mk中应该增加moule名,而且在IdentityCard.h中应该增加CODE,谢啦!同时也多谢zzzrrr兄!
发表于 2006-2-13 10:21:59 | 只看该作者
看论坛学英语,好!哪天我的英语也这么好就好了
发表于 2006-2-14 11:21:55 | 只看该作者
大哥们,又遇到问题了,我的VBA程序里含有Selection.SelectElement2 的语句,我看CAA帮助说需要用 CATApplication.Subscribe 来返回第一个参数值,可是小弟不会用啊,哪位大哥会用CATApplication.Subscribe语句?
GMT+8, 2025-4-4 22:44 , Processed in 0.028061 second(s), 13 queries , Gzip On, Redis On.
