查看: 16284|回复: 2
请问每次换刀都输出刀具信息详设步数?我设败了
发表于 2006-2-11 12:15:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问每次换刀都输出如下格式刀具信息详设setup(在POST BUILDER中设置):
(TOOL MILL D10.0  R5.0)
M06 T12
在ADD Block  Operator Massage中填Tool Diameter: $mom_tool_diameter处理时报警
[ 本帖最后由 ssfjyv 于 2006-2-11 15:37 编辑 ]
发表于 2006-2-11 13:14:27 | 只看该作者
//                                   T O O L   L I S T
//MILL                 DESCRIPTION          DIAMETER   COR RAD    FLUTE LEN  ADJ REG
//D8                   平底刀 8 mm            8.0000     0.0000     8.0000     0
//D6R0.5               牛鼻刀 6R0.5 mm        6.0000     0.5000     30.0000    0
//D2R1                 波头刀 2 mm           2.0000     1.0000     5.0000     0
G90G28Z0
M30
// TOTAL Machine Time: 69.10
# The desired tool list type can be set by changing the code below.
# The default is set to "GROUP_BY_TYPE".
   global mom_sys_tool_list_initialized
   global mom_sys_tool_list_output_type
   if { ![info exists mom_sys_tool_list_initialized] || !$mom_sys_tool_list_initialized } {
      MOM_output_to_listing_device "proc PB_CMD_init_tool_list must be executed in the Start of Program before
PB_CMD_create_tool_list is called."
return
  # Set mom_sys_tool_list_output_type to the desired output fashion.
  #   "ORDER_IN_USE"     - List tools used in the program in the order of operations.
  #   "ALL_UNIQUE"       - List all unique tools once for each in the order of use.
  #   "GROUP_BY_TYPE"    - List tools in groups of different tool types.
  # set mom_sys_tool_list_output_type "ORDER_IN_USE"
  # set mom_sys_tool_list_output_type "ALL_UNIQUE"
   set mom_sys_tool_list_output_type "GROUP_BY_TYPE"
   global mom_sys_control_out mom_sys_control_in
   global current_program_name
   global mom_tool_number mom_tool_length_adjust_register mom_tool_name
  # Save info for the currently active tool in the program being post-prcessed
  # before starting Shop Doc mechanism for tool list generation.
   if [llength [info commands PB_CMD_save_active_oper_tool_data] ] {
  # Create tool list per selected top-level group.
  # Group name is set to blank if no group has been selected.
   global mom_parent_group_name
   if [info exists mom_parent_group_name] {
      set current_program_name $mom_parent_group_name
   } else {
      set current_program_name ""
   set ci " "
   set co " "
   if [info exists mom_sys_control_in] { set ci $mom_sys_control_in }
   if [info exists mom_sys_control_out] { set co $mom_sys_control_out }
  # Generate tool list data
   set template_file pb_post_tool_list.tpl
   global tcl_platform
   if [string match "windows" $tcl_platform(platform)] {
      set pb_lib_misc_dir [MOM_ask_env_var UGII_BASE_DIR]\\postbuild\\pblib\\misc\\
   } else {
      set pb_lib_misc_dir [MOM_ask_env_var UGII_BASE_DIR]/postbuild/pblib/misc/
   set cam_post_dir     [MOM_ask_env_var UGII_CAM_POST_DIR]
   set cam_shop_doc_dir [MOM_ask_env_var UGII_CAM_SHOP_DOC_DIR]
   if { [file exists ${pb_lib_misc_dir}${template_file}] } {
      MOM_do_template_file ${pb_lib_misc_dir}${template_file}
   } elseif { [file exists ${cam_post_dir}${template_file}] } {
      MOM_do_template_file ${cam_post_dir}${template_file}
   } elseif { [file exists ${cam_shop_doc_dir}${template_file}] } {
      MOM_do_template_file ${cam_shop_doc_dir}${template_file}
   } else {
      MOM_output_to_listing_device  "ERROR : Template file pb_post_tool_list.tpl is not found in the following directories:
\n \n          $pb_lib_misc_dir \n          $cam_post_dir \n          $cam_shop_doc_dir \n \n        Tool list cannot be
generated.\n"
return
  # Tool list header
   shop_doc_output_literal
"$co===============================================================================================$ci"
   shop_doc_output_literal "$co                                   T O O L   L I S T
$ci"
  # Output tool list
   global tool_data_buffer
   global mom_sys_tool_stack
   switch $mom_sys_tool_list_output_type {
      "ORDER_IN_USE" {
         set tool_list $mom_sys_tool_stack(IN_USE)
      "GROUP_BY_TYPE" {
         set tool_list [concat $mom_sys_tool_stack(LATHE)  $mom_sys_tool_stack(DRILL)  $mom_sys_tool_stack(MILL)]
      default {
         set tool_list $mom_sys_tool_stack(ALL)
   set prev_tool_type ""
   foreach tool $tool_list {
      set tool_type $tool_data_buffer($tool,type)
     # Output tool type header if it changes.
      if { ![string match "$tool_type" $prev_tool_type] } {
         if { [info exists tool_data_buffer($tool_type,header)] &&  $tool_data_buffer($tool_type,header) != "" } {
            shop_doc_output_literal "$tool_data_buffer($tool_type,header)"
      if [info exists tool_data_buffer($tool,output)] {
         shop_doc_output_literal "$tool_data_buffer($tool,output)"
      set prev_tool_type $tool_type
  # Tool list footer
  # Restore info for the currently active tool in the program being post-prcessed.
   if [llength [info commands PB_CMD_restore_active_oper_tool_data] ] {
发表于 2006-2-11 15:50:29 | 只看该作者
谢谢PENGCHENG兄!
可否不直接修改TCL文件与DEF文件? 我想在POST BUILDER中设置,怎么做?如要修改TCL文件与DEF文件怎么做?(但这会使它们与PUI文件,POST BUILDER失去联系)
GMT+8, 2025-4-21 04:29 , Processed in 0.021993 second(s), 12 queries , Gzip On, Redis On.
