查看: 16706|回复: 3
能说一下UG18中文版怎么汉化吗?
发表于 2003-2-6 22:54:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位老大能详细说一下UG18中文版怎么汉化吗?
发表于 2003-2-6 23:01:15 | 只看该作者
UG18已经自带中文,文件放在ugs180\LOCALIZATION下。
可以将ugii_simplified_chinese.lng改名为ugii.lng
在UGS180下建立CHINESE目录,将LNG文件拷到此目录,在建立一新文件UG18CHN.BAT 内容如下:
rem
set PATH=%UGII_BASE_DIR%\ugii;%PATH%
rem
rem MOTION PRODUCT
rem
rem ADAMS requires the following three variables to be set:
rem
set LM_LICENSE_FILE=%UGII_BASE_DIR%\mech\license.dat
set MDI_AVIEW_MESSAGES=%UGII_BASE_DIR%\mech\aview.msg
rem
rem Check UGFLEXlm License service.
"%UGII_BASE_DIR%\ugflexlm\lmutil" lmstat -c %UGII_LICENSE_FILE% > NUL
if ERRORLEVEL 0 goto run_ug_validate
if ERRORLEVEL -13 goto server_error
rem
:run_ug_validate
rem Run ug_validate.
rem
set UGII_LANGUAGE=%UGII_BASE_DIR%\chinese
"%UGII_BASE_DIR%\ugii\ug_validate" > NUL
if ERRORLEVEL 1 goto error_exit
start "Title" "%UGII_ROOT_DIR%\"ugraf.exe %*
goto normal_exit
:server_error
echo ERROR: Unable to start Unigraphics. The License server(s) defined in
echo the UGII_LICENSE_FILE environment variable did NOT respond.
echo Current Setting: %UGII_LICENSE_FILE%
echo Check: UGII_LICENSE_FILE and that server(s)
echo are running.
echo To check the server(s) use:
echo disk:\ugs180\ugflexlm\lmutil lmstat -c %%UGII_LICENSE_FILE%%
rem
:error_exit
pause
:normal_exit
endlocal
@echo on
发表于 2003-2-7 16:42:24 | 只看该作者
将ug180\ugchinese下ugchinese.bat用记事本打开
最后一句改成%UGII_BASE_DIR%\ugii\ugii.bat
存盘再打开此文件
发表于 2003-2-7 23:19:46 | 只看该作者
建议大家不要用中文菜单,某些菜单项会不见了,翻译得也很别扭
GMT+8, 2025-2-27 05:34 , Processed in 0.025660 second(s), 13 queries , Gzip On, Redis On.
