查看: 20698|回复: 7
我用Moldflow5.1做的冷却分析,请各位高手指点一下分析失败的原因.万分感谢!
发表于 2006-2-20 15:54:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Copyright Moldflow Corporation and Moldflow Pty. Ltd. All Rights Reserved.
(C)1993 1994 1995 1996 1997 1998 1999 2000
(C)2001 2002 2003 2004
This product may be covered by
   US patent 6,096,088 ,
   Australian Patent No. 721978 ,
and foreign patents and pending applications
Cool Analysis
Version: mpi500  (Build 04305)
Analysis running on host:
        Operating System: Windows 2000 Service Pack 4
          Processor type: AuthenticAMD x86 Family 15 Model 12 Stepping 2 ~1602 MHz
    Number of Processors: 1
   Total Physical Memory: 511  MBytes
Analysis commenced at        Mon Feb 20 11:22:25 2006
Executed: Mon Feb 20 11:22:25 2006
   Mesh Type                                          = Fusion
   Number of nodes                                    =        4691
   Number of beam elements                            =          87
   Number of triangular elements                      =        9254
   Number of tetrahedral elements                     =           0
Reading nodal data...
Reading beam element data...
Reading triangular element data...
   Method of calculating geometrical influence        = Automatic
   Cooling analysis type                              = Manual
   Total number of part elements                      =        9259
   Total number of runner elements                    =           5
   Total number of mold elements                      =          82
   Total number of circuit elements                   =          82
   Co-ordinates of part extremity:
                        X             Y             Z
      Maximum         36.55000 mm     36.55000 mm     71.52000 mm
      Minimum        -36.54970 mm    -36.55000 mm      0.00000 mm
      Orientation    109.65000 mm    109.65000 mm    143.04000 mm
** ERROR 701580 ** Orientation of two adjacent elements is inconsistent.
                   Angle between normals = 1.79844E+02 deg degrees.
** ERROR 701590 ** Check the orientation of element     438
** ERROR 701590 ** Check the orientation of element     442
                   Angle between normals = 1.79841E+02 deg degrees.
** ERROR 701590 ** Check the orientation of element    1868
                   Angle between normals = 1.79729E+02 deg degrees.
** ERROR 701590 ** Check the orientation of element    1880
我用Moldflow5.1做的冷却分析,但是分析失败,请各位高手指点一下分析失败的原因.万分感谢!
发表于 2006-2-20 16:41:32 | 只看该作者
网格质量有问题。看看是不是有重叠交叉。
发表于 2006-2-21 15:57:34 | 只看该作者
我看問題不是質量的問題, 而是 orientation 的問題。
在 orientation diagnosis 中, 看看 orientation 是否一致。如果不一致,可以用 orient all 的功能改變 orientation.
至於 top 同 bottom 的問題, 就視乎你的模型了。
发表于 2006-2-21 19:09:07 | 只看该作者
很明显有两处网络orientation不一致
发表于 2006-2-22 09:38:40 | 只看该作者
虽然提示的是两个网格的配向有问题,但实际并不是这样,你可以通过ID查出这些网格,然后细部看一下他们的结构,应该是属于重叠或者交叉的问题,但在网格诊断里面显示不出来.
发表于 2006-2-22 12:18:10 | 只看该作者
你遇到的问题跟我昨天碰到的一样!是你的网格有问题,有重叠面
可以通过查找找出来
比如上面的那条,是你的438号面跟442号面有问题,你可以通过查找元素  T438 跟 T442(注意前面加T或者N),找到这两个问题面,修复就可以了!你可以试试看
发表于 2006-3-9 00:21:54 | 只看该作者
怎么判断是加T还是加N?
发表于 2011-12-26 09:32:08 | 只看该作者
查找元素工具在那里?
GMT+8, 2025-4-28 12:35 , Processed in 0.030623 second(s), 11 queries , Gzip On, Redis On.
