查看: 16342|回复: 3
CATIA Interactive Session 的一個問題
发表于 2006-2-21 11:40:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我想知道,如果我現有一個VC++ 6.0的程式,而這個程式是不斷運行.當有雖要時,這個程式有沒有可能與CATIA的Interactive Session程式連繫.用這個程式呼叫CATIA做一些如放大,縮小的功能?
发表于 2006-2-21 14:11:11 | 只看该作者
at least 2 choices:
1.backbone
2.socket
发表于 2006-2-21 14:26:23 | 只看该作者
你可以用一些程式的例子說明嗎?
发表于 2006-2-21 14:47:52 | 只看该作者
>>你可以用一些程式的例子說明嗎?
For backbone, please refer to CAADoc/Dialog.edu or something, there is a good sample inside. search with "CORBA" may make it easier to find the source.
And of cause you have to also give a good read of the section Backbone in encycropedia.
For socket, you can refer to any network programming related book.
Don't ask sample code from me, I don't have. Actually nobody have such a good sample just fits your needs.
GMT+8, 2025-4-9 20:11 , Processed in 0.026393 second(s), 10 queries , Gzip On, Redis On.
