查看: 16454|回复: 3
CAA高手帮忙看看状态转移的问题
发表于 2006-2-23 17:00:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AddTransition( stState2, stState3,
                 IsOutputSetCondition (_ElementAgent1),
                 Action ((ActionMethod) &SimAnglePlaneCmd::SelectLine));
   AddTransition( stState3, NULL,
                 IsOutputSetCondition (_OKAgent),
                 Action ((ActionMethod) &SimAnglePlaneCmd::OkAction));
这样点击ok时 程序没有反映 ?是不是状态转移的有问题?
多谢
想了n久
用这个办法我做成了线的复制 但这样做面的旋转时 就不行了
发表于 2006-2-23 17:03:28 | 只看该作者
state 是这样设置的
CATDialogState *stState1 = GetInitialState("Surface");
    stState1 -> AddDialogAgent (_ElementAgent);
    CATDialogState *stState2 = AddDialogState("Line");
    stState2 -> AddDialogAgent (_ElementAgent1);
    CATDialogState *stState3 = AddDialogState("OK ");
    stState3 -> AddDialogAgent (_OKAgent);
    CATDialogState *stState4 = AddDialogState("CONCEAL ");
    stState1 -> AddDialogAgent (_CancelAgent);
发表于 2006-2-23 17:37:44 | 只看该作者
Did you add any callback for the OK button for your dialog? (in your source file of the dialog/panel)
if yes, the transaction won't work.
发表于 2006-2-24 09:43:28 | 只看该作者
yeah.i have added the callback function for OK button.
the problem have been solved. Thanks Saeba.
because i do other executing function in Dlg.cpp. so delete them . then it's ok.
thanks very much!
GMT+8, 2025-4-10 06:05 , Processed in 0.020294 second(s), 11 queries , Gzip On, Redis On.
