查看: 15724|回复: 0
[求助]在做压电陶瓷的瞬态分析时出现了如下提示!!
发表于 2006-3-23 11:18:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
个位大虾,我做压电陶瓷的瞬态分析,在向
nsel,s,loc,x,10
cp,11,volt,all
*get,front,node,,num,min
ALLSEL
finish
antype,trans,new
trnopt,full
eqslv,sparse
betad,0.1/7650
d,front,volt,800
这时出现一个警告对话框:
Both solid model and finite element model boundary conditions have been
applied to this model.  As solid loads are transferred to the nodes or
elements, they can overwrite directly applied loads.
求解完之后,压电陶瓷片一端的位移是0,不知到底哪一步出现了问题,请指教!谢谢!!
GMT+8, 2025-4-5 10:43 , Processed in 0.019126 second(s), 11 queries , Gzip On, Redis On.
